Old 10-06-2007, 08:22 PM   #1 (permalink)
Default Problem in Monitor
Hi, I'm having XP Home SP2 for the last 2 yrs but did never experience such a peculiar problem. It happens like, in my monitor, if I want increase or decrease the brightness or contrast I would press the buttons of the monitor & can adjust as I wish. But for the last few days I'm seeing that, the onscreen display (i.e. the display we see after pressing those buttons) appears in the monitor on its own and keeps on coming and disappearing continuously. (I'm not sure whether my problem is made clear or not) In the Device Manager I've checked the status of Monitor n in the Properties therein it shows the 'device is working properly'. This gives a lot of troubles in my working. Would you please suggest me something to fix it?
Kerry is offline
Old 10-06-2007, 08:32 PM   #2 (permalink)
Default Re: Problem in Monitor
Yeah got the problem...
Mus be a problem within the monitor...
Onscreen displays of the monitor isn't in d control of the OS...
Mus be a problem with some chips/ICs inside...
Wat brand is dat??? Check d warranty/AMC n get an authorised service personnel n get it checked... Dun mend with it by urself...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 13-12-2007, 01:41 PM   #3 (permalink)
tango_cash's Avatar
even i have the same problem.any one got a solution???
tango_cash is offline
Old 13-12-2007, 10:57 PM   #4 (permalink)
Take it to the repair shop.....it's a common problem with aging monitors..... probably some loose solder or the switch contacts gone bad.
Let there be music.....
sashijoseph is offline
Old 13-12-2007, 11:24 PM   #5 (permalink)
dOm1naTOr's Avatar
Switch problem...me too had the problem with my old Samsung 56v CRT.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Monitor Problem prasha1982 Hardware Q&A 2 23-10-2006 03:07 PM
MONITOR PROBLEM( in 17'') nittn_only_4u1 Hardware Q&A 2 23-01-2006 06:12 PM
Problem With My Monitor and UPS navino87 Hardware Q&A 7 08-01-2006 11:40 AM
Monitor Problem Panda QnA (read only) 5 18-09-2005 08:11 PM
Monitor Problem hikapil QnA (read only) 7 31-03-2005 07:45 PM
