Old 10-06-2007, 06:12 PM   #1 (permalink)
Default The best dvd writer
I am planning on buying a new DVD writer....suggest a good one for me.....
spartan2k7 is offline
Old 10-06-2007, 06:15 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: The best dvd writer
In my opinion all Sony, Samsung, Liteon, LG are good. Lite on has a good brand image though
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 10-06-2007, 06:18 PM   #3 (permalink)
Had a samsung and sony dvd writer.....and both of them had ejecting problems.....is the Lg good?
Old 10-06-2007, 08:44 PM   #4 (permalink)
Those're really rare n depends on our handlin...
We musn't force the trays inside... Esp wen d syst goes off wen the tray's out...
Lg's jus ok.. Nuthin so good...
Sony n Lite-on's best... Plextor was also good....
Then ther're Pioneers' with 16MB caches n all ouut our reach....
Sony DRU-835/DRU-170c... good ones...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 10-06-2007, 09:07 PM   #5 (permalink)
harryneopotter's Avatar
Lite-On Rocks !!!!!!!!!!!!!!!!
harryneopotter is offline
Old 10-06-2007, 10:45 PM   #6 (permalink)
NP : Crysis
xbonez's Avatar
lite on is quite good but availablity and finding service centers is a prob in small towns
xbonez is offline
Old 11-06-2007, 12:15 AM   #7 (permalink)
CA50's Avatar
LG is good i am using it and no pros till now, writting speed is also good.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 11-06-2007, 02:44 AM   #8 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
sony dvdrws are repackaged BENQs. so go for BENQ. its cheaper by 100-200 bucks.
This Space Has Been "RESERVED" !!!
pannaguma is offline
DVD writer int86 Hardware Q&A 32 12-01-2007 01:21 PM
Which DVD Writer among these is the best?? thilina QnA (read only) 27 05-10-2006 04:48 PM
Which DVD writer should I buy? abhinav QnA (read only) 29 07-12-2005 09:02 AM
DVD-ROM or DVD-Writer smash555 QnA (read only) 5 22-08-2005 11:45 AM
