Old 10-06-2007, 07:56 AM   #1 (permalink)
pushkaraj's Avatar
Unhappy Urgent Help Needed:usb Hdd Problem!!!
I have a 3.5" internal Samsung SP0411N PATA drive converted into an external one through the ide to usb converter kit. The problem is when i was copying a folder from my pc to the external hdd, the pc froze. So i switched off the power supply to the external hard disk. Suddenly the pc came to life and a message popped up in the taskbar with the heading "Delayed write failed". From then on, the external drive doesn't show up in windows explorer or even in disk management. It however shows up in device manager.
Does this mean i hav lost all data or worse , has the disk failed ???
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 10-06-2007, 08:43 AM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: Urgent Help Needed:usb Hdd Problem!!!
You'll need to manually remove it from the casing & shift it to your PC & then try to see if it gets detected or not.Also check if the data is intact & can be copied or not.Usually these cheap casings are the main culprits in this department.Not sure what their actual problem is but they fail to consistently transport data after a certain point.In my case,I have 2 of my friends USB HDD's lying around & one of which has crashed due to this poor performance casing & the second one is just coughing up signs of dying.
V for Vendetta
Ethan_Hunt is offline
Old 10-06-2007, 10:39 AM   #3 (permalink)
pushkaraj's Avatar
As they say, calamity strikes when u least expect it . I had actually come to my cousin's place to get some data from him and this bloody external thing betrayed me . Anyways thanx a lot. Will definitely try ur suggestion .
Hey allwyndlima, GOOD NEWS. I just kept the external hd for a while to cool it off. And now EUREKA!!! It has started working. U know these electronics sometimes really piss me off.................lol.........................
Hey can sum1 tell , i want to format one of the partitions of my external hd. So is it better to keep a smaller allocation size or should i go for a bigger one??? Also i want to know wat diff does either of them make???
Old 10-06-2007, 11:24 AM   #4 (permalink)
Ethan_Hunt's Avatar
Usually depends on the type of data you are about to store.If you ought to put on huge games then you are better off with bigger partitions & please make sure everyone is in NTFS mode.The less the number of partitions the lesser the confusions IMO.
V for Vendetta
Old 10-06-2007, 12:15 PM   #5 (permalink)
pushkaraj's Avatar
No i think u misunderstood me. I am talking about the allocation unit size which is an option when we format a particular partition
Old 10-06-2007, 12:39 PM   #6 (permalink)
Ethan_Hunt's Avatar
The first partition which would be primarily for the OS then it should be atleast 10GB.The rest could depend on what size of HDD you have.Or am I still missing your point?
V for Vendetta
Old 10-06-2007, 12:50 PM   #7 (permalink)
pushkaraj's Avatar
Red face Re: Urgent Help Needed:usb Hdd Problem!!!
You r still missing my point. Check out the screenshot. This is the dialog box u get when u right click on ur partition and click on format.
Old 10-06-2007, 01:17 PM   #8 (permalink)
Ethan_Hunt's Avatar
Oh ok now I get it.Just leave it to default & it should be fine.
V for Vendetta
Old 10-06-2007, 02:11 PM   #9 (permalink)
pushkaraj's Avatar
Thumbs up Re: Urgent Help Needed:usb Hdd Problem!!!
Ok Thanx
Urgent help needed for Tata indicom problem sushantsaurabh QnA (read only) 6 09-05-2007 04:43 PM
Urgent Help Needed 2 Solve Win Xp Problem SLIPKNOT Software Q&A 7 17-11-2006 12:22 PM
Serious Problem about Display......Urgent Help Needed dissel Hardware Q&A 5 19-03-2006 09:17 PM
Hardware Problem.....Urgent help needed ....!!! jay4u QnA (read only) 3 29-04-2005 11:00 PM
Problem with my Monitor. Urgent Help needed. Yoda QnA (read only) 5 02-11-2004 10:10 AM
