My LG GSA H20N DVD-RAM drive has started acting up after i upgraded its firmware from 1.01 to 1.02. It does not giv any problem in xp but when i boot in vista, it gets recognised as an unkown hardware found. It says it was not able to get the drivers for this particular device. I don't understand the link between firmware and drivers. Can sum1 help me?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
I had updated the firmware using the LG online update software. The most surprising thing about the firmware update was its description:
Supports Vista.
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
Re: DVD-RW problem!!!
I have a BENQ DW1650. approx 13 months old. It gives a write error when starting a DVD, right at 0%. on nero it says write process failed. what could be the problem?
This Space Has Been "RESERVED" !!!
@pushkaraj after selecting update driver option in device manager,choose the 'Browse my computer' option and then select the drive on which Vista is installed.
