Old 09-06-2007, 06:10 PM   #1 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Question Dual core - AMD or INTEL ?
Hi frenz, i'm about to take a new pc,i want to know which dual core is best, AMD or intel.. I'll be using mainly for video editing, video encoding etc.. Can you pls suggest me the best processor and mother board pls..
anish_sha is offline
Old 09-06-2007, 06:23 PM   #2 (permalink)
Default Re: Dual core - AMD or INTEL ?
Uh...
Core2Duo obviously n fer those apps its outta question...
Budget pal.... We need the budget fer dat...
Lets say...
The C2D E4300- 5k + Asus P5B-VM - 7400 fer starters... (O'clock n get the xtra edge!!!)
Fer enthusiasts go fer the C2D6600 + ASus P5B Dlx- 21000 net
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 09-06-2007, 11:15 PM   #3 (permalink)
Anindya's Avatar
Question Re: Dual core - AMD or INTEL ?
Can AMD proccy be overclocked?
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 10-06-2007, 12:41 AM   #4 (permalink)
Of corz yes... But wont match d performance wen a C2D's o'clocked tho!!!
AM2+ may still be better o'clockers but they havn't yet released...
Old 10-06-2007, 01:22 AM   #5 (permalink)
dOm1naTOr's Avatar
But value for money is for AMD as their mobos are also cheaper.
u can get the 5000+ for less than 8k now.
But if u have the money to shell out, say some 15k for CPU nd mobo then go for C2D.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
diff between Intel dual core,Core 2 , Duo?? NagpurDaMunda CPU / Motherboards 26 21-07-2007 06:37 AM
Intel dual core without HT or AMD64 dual core--which is best vps85 CPU / Motherboards 2 26-04-2005 01:02 AM
Intel Dual Core processors devilhead_satish CPU / Motherboards 4 09-04-2005 02:17 PM
