Old 09-06-2007, 12:33 PM   #1 (permalink)
Techzilla!
rahul30's Avatar
Default ram compatibility
i have a kingston 1gb ddr2 ram and i want to add another 1gb stick...can i pair that with a corsair 1gb stick???? will it work??
amd x4 635 , Gigabyte 880 GM-UD2H, 2gb ddr3 corsair, 500 gb w.d caviar green, benq G2220hd , CM 310, CM 500w Extereme Plus , Tritton AX 720 Pro
rahul30 is offline
Old 09-06-2007, 12:37 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: ram compatibility
yup... it ll...
just make sure that both hav the same frequencies... and obviously both shd be ddr2..
Pathik is offline
Old 09-06-2007, 12:40 PM   #3 (permalink)
Techzilla!
rahul30's Avatar
yes man i have 667mhz ram and will be pairing it with the same frequency...thanks for the info buddy...coz some1 was telling me that it wont be possi
rahul30 is offline
Old 09-06-2007, 04:59 PM   #4 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
@pathiks - i have an ancient comp running on sd-ram. its has 2x128MB ram, of which one is 100MHz and other is 133MHz, and working fine. then why do u say " just make sure that both hav the same frequencies"???
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 09-06-2007, 11:05 PM   #5 (permalink)
NP : Crysis
xbonez's Avatar
^^the 133mhz ram module will also be running at 100mhz (i also used to run two such modules on my prev comp)
@rahul: as long as frequencies match, they will work just fine. however, don't try to run them in dual channel config. it may cause stability issues
xbonez is offline
Old 10-06-2007, 09:47 AM   #6 (permalink)
darklord's Avatar
Along with speed, timings matter too. Timings available in the SPD tables should match and work with each other. Or else you will have to go into BIOS and set timings manually.
darklord is offline
Old 10-06-2007, 10:17 AM   #7 (permalink)
Google Bot
Pathik's Avatar
If thats the case then both the modules will work on 100mhz... so having a 133mhz wont make performance improvement...
Pathik is offline
Old 10-06-2007, 05:19 PM   #8 (permalink)
Turn The Page
pannaguma's Avatar
^^ ok. but everest showed them to be 100 & 133 MHz.
RAM Compatibility bhoolkumehul Hardware Q&A 4 04-02-2007 07:58 PM
64 bit compatibility vipashdigit QnA (read only) 4 29-11-2006 11:39 PM
RAM compatibility Help d33p4k Hardware Q&A 14 07-03-2006 02:50 PM
DDR RAM Compatibility vinayasurya QnA (read only) 3 19-06-2005 12:31 AM
RAM Compatibility..... justo QnA (read only) 2 03-12-2004 10:32 PM
