Old 08-06-2007, 03:22 PM   #1 (permalink)
Kalyan's Avatar
Default Help me choose LCD Monitor
Hi all..
I have posted my requirements earlier. I am doing it again, just in case. I need an LCD Monitor 17" I will be using it for programming, gaming and movies, a little bit of image editing stuff. My budget is 10k. a little bit more/less is comfortable. The lesser the price, the more happier I am. I need to buy tomorrow. Please suggest me one.
My choices,
1) LG L1752S
2) LG L1719S
3) Viewsonic 1703wb
4) Samsung 740N (Last month digit wrote it as a low performer while the VS 1703 a good performer)
Please help me choose. My deadline is tomorrow.
Kalyan is offline
Old 08-06-2007, 04:29 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Help me choose LCD Monitor
It would be lot better to go for 19inch widescreen since they are just 11k and have better Response times, contrast and Brightness ratios.
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 08-06-2007, 09:16 PM   #3 (permalink)
Kalyan's Avatar
OK. I shall consider. But I would be happier if you have suggested 19" monitors even. Please I need to buy it tomorrow.
Kalyan is offline
Old 10-06-2007, 11:15 AM   #4 (permalink)
Host4Cheap.org
Well after checking a lot, reading reviews and personally checking at the assembler, i settled for BenQ FP92W for 11500. For me it is complete in Features : Has DVI, Low Response time of 5ms, Good Viewing Angles and Contrast, Brightness Ratios and steady stand
Help me to choose parimal Mobiles and Tablets 14 18-05-2007 04:08 PM
Help me choose Kalyan Mobiles and Tablets 10 24-01-2007 12:10 AM
help me choose cyberzook Mobiles and Tablets 2 18-10-2006 12:41 AM
Choose your CPU... akshayt Hardware Q&A 8 13-07-2006 06:11 AM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
