08-06-2007, 12:25 PM
Random Username
Good mobo for C2D
Is there any good mobo for Intel Core 2 Duo with decent onboard graphics? I'll get a graphics later when prices drop, so temporarily I'm planning to use onboard graphics. My budget is around 5k.
08-06-2007, 01:07 PM
Re: Good mobo for C2D
Your only option is Intel G965 based mobos.
08-06-2007, 01:55 PM
Host4Cheap.org
Intel 965RY seems to be in your budget and has onboard graphics
http://www.host4cheap.org/
08-06-2007, 02:10 PM
Random Username
Thanks, but are you sure that the model is 965RY? I google and found only DG965RY.
08-06-2007, 02:13 PM
Commander in Chief
Both are the same. He simply didn't prefix DG
Harsh J
www.harshj.com
08-06-2007, 02:16 PM
Rebooting
Certanly i would suggset not to go for D965RY, the board doesnt worth to be with C2D
if one has to buy a D965 based board it has to be either D965WH or ASUS P5B-V
rebooting
ChotoCheeta.com
08-06-2007, 02:43 PM
Random Username
But I'm not sure whether D965WH or ASUS P5B-V will fit into my 5k budget.
Acording to ITWares D965WH costs 7.6K
Is D965RY not a good board?
08-06-2007, 02:50 PM
965RY has ram compatibility issues.either increase ur budget or buy a AMD X2 based system.its better to buy X2 when ur a bit tight on budget.
08-06-2007, 04:28 PM
Host4Cheap.org
All Intel Boards have issue with RAM at 800MHZ and BIOS locket at 1.8v. But 80% people would be getting 667MHZ ram so it wont be of much problem.
I have DG965WH and my friend has DG965RY not much issues till now
08-06-2007, 05:42 PM
Rebooting
@weftr100
if u have a budget problem then C2D isnt for u, how ever saing that I support sukhdeepsinghkohli that, buy 667MHz RAM then D965RY wont be such bad buy !!!
but once again, as assasin said, think of X2 for a Value for money system !!!
rebooting
ChotoCheeta.com
09-06-2007, 12:04 PM
Random Username
Thanks for your replies. So is there a good mobo for AMD with decent onboard graphics? I have decided to go for AMD X2 4800+.
09-06-2007, 12:23 PM
Techzilla!
asus m2a-vm @ rs. 4000 (more than decent gfx)...loook no further
amd x4 635 , Gigabyte 880 GM-UD2H, 2gb ddr3 corsair, 500 gb w.d caviar green, benq G2220hd , CM 310, CM 500w Extereme Plus , Tritton AX 720 Pro
14-06-2007, 03:48 PM
I M BACK , WITH A BANG
intel 965 mobo is a strict no no for a C2D processor,
it will bottleneck your PC's performance for sure,
u can go for ASUS 650i ultra which costs around 5.5K,
but hey no onboard gfx with this mobo ,
but performance is good,
get a ceap gfx card like 6200 for temporary soultions , will cost you 1800-2000Rs,
plz don't go for the intelD965RY or D965WH also P5B VM,
don't think about these 3 mobos,
about AMD,
there are lots of mobo's with better onboard gfx than intel onboard,
in AMD you have
ASUs M2N Mx with 6100 onboard costs 3800Rs,
then ASUS M2N Pv Mx 6150 onboard 4000Rs,
then u have ASUS M2A VM (ATI 1250 onboard) 4500Rs,
& ASUS M2A VM HDMI (ATi 1250 onboard)with HDMI support 5000Rs,
another option gigabyte mobo with geforce 7050 around 5-5.5K,
another cheap option jeyway 690G chipset (same as ASUS M2A VM) 3800Rs,
My Greatness Cannot be Expressed in Terms Of normal Word's,It Requires a Compiler
-By saggygenius
14-06-2007, 04:49 PM
^care to explain how/why it would bottleneck his processor? I own a DG965RY myself & don't seem to find any sort of issues with it nor any issues of the processor being bottlenecked.Also AFAIK many of my friend who own a 965 boards with a medium/high end DX10 cards on it aint complaining of any sort of "bottleneck" issues.
Again WHY?
V for Vendetta
14-06-2007, 05:01 PM
Host4Cheap.org
Again WHY?
Yeah i wanna know too...  If you wanna say that there is no overcloking...then we know
14-06-2007, 05:13 PM
i haven't said all the 965 mobo's
i have specified the ones which are useless,
see the intel onboard gfx sux totally,
also there is no overclocking options available in those mobos
(excluding P5B VM which has limited overclocking capability)
features are absent which are on the chipset based mobo's from ASUS ,
an A I overcloking would have been better for that mobo,
-By saggygenius
14-06-2007, 05:19 PM
Host4Cheap.org
LOL, Most of the average user is looking for Onboard graphics so he doent need to spend few more thousands just to surf websites and make documents.
Plus the onborard GFX is capable of most games if not in Eye candy
Good news for Intel G965 Users who use integrated graphics
Offcourse, there is no overclocking in Intel but just remember...not all people are gamers
What important feature is absent ??  Dont mislead people with useless comments
14-06-2007, 05:24 PM
ha ha.. .
then why to buy a C2D,
C2D's are meant for overclocking,
if anybody dont want to overclock then AM2 is the way to go,
why to waste money
-By saggygenius
14-06-2007, 05:25 PM
#19 (permalink)
Host4Cheap.org
ha ha.. .
why to waste money
WOW, and intel who made that processor didnt knew that their procesoor was only for overclocking. Amazing isnt it
Very very good bolbachan.Try TV....they need tons of em
14-06-2007, 05:31 PM
#20 (permalink)
ha ha
intel is not making the overcloking supported mobo's cause they are not giving any warrenty after overclocking,
thats common sense , not bol bachchan giri
-By saggygenius
14-06-2007, 05:34 PM
#21 (permalink)
Host4Cheap.org
ha ha
Really OMG  Sachi Muchi ...
14-06-2007, 05:36 PM
#22 (permalink)
yeah my boy
thats the naked truth of intel
-By saggygenius
14-06-2007, 05:38 PM
#23 (permalink)
Host4Cheap.org
yeah my boy
Thats the naked truth how people love to post toally useless comments and misguide people
14-06-2007, 05:43 PM
#24 (permalink)
i m not misguiding anybody here,
if anybody dont wanna listen ,then thats their choice,
anyways , anydays the other mobos are better,
-By saggygenius
14-06-2007, 05:50 PM
#25 (permalink)
Host4Cheap.org
Then what were you doing when you said,
Intel has Totally crap onboard GFX ->> it is able to play most games if not in full eye candy. You really cant compare it with 8800GTX,, can you ?
Then another one, Intel board only work on 500W PSU - Crap again. Works fine on my 450W and my friends 400W
Intel MOBO's are missing important features ->> and you didnt mention they Important features.
Overclocking- yes, agree.....but everyone know Intel MOBO are not overclockers.
Dont trash something for you ignorance
14-06-2007, 05:57 PM
#26 (permalink)
The Thread Killer >:)
The guy who started the thread forgot to mention what his exact needs are. The DG965RY is decent enough for medium end gaming(after the install of the beta drivers) I vote for this mobo
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
14-06-2007, 05:58 PM
#27 (permalink)
965 mobo is a bottleneck in C2D rigs??
wake up dood!!where hav u been in all these days??wat got u to make a comment like that??r u intoxicated??
P965 chipset based mobos r one of the best mobos for C2D proccies.most ppl using C2Ds use mobos based on this chipset.the P965 chipset is better than the nVidia 650 chipset.
14-06-2007, 06:02 PM
#28 (permalink)
Host4Cheap.org
Already told him that
14-06-2007, 06:04 PM
#29 (permalink)
HELP AND SUPPORT
I just Now purchased a New PC
Processor: Intel Core 2 Duo 1.80Ghz
Motherboard: Intel DG965RY
I got a Transcend 1GB DDR2(667MHz) RAM...Does 965RY have Ram compatibility issues? Can I over clock with this configuration and If so How?
Pheww...I just didn't know about this at all..!!! Luckily I got a Transcend 1GB DDR2(667MHz) RAM.  I really need to start learning About Hardware which i have kept on ignoring right from the Beginning
14-06-2007, 06:15 PM
#30 (permalink)
with ClockGen u can but its not at all recommended.ur mobo doesnt support oc thru BIOS.
