Old 08-06-2007, 12:24 AM   #1 (permalink)
CA50's Avatar
Question Mute XP SP2
I hv got a CelD 2.66, 256mb, 80GB pc runing XP SP2. My pc doesn`t give the usual startup N shutdown sounds. This happened after installing the Autopatcher XP 4m Digit CD.
Plz help...
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 08-06-2007, 06:45 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: Mute XP SP2
Start->Control Panel->Sounds and Audio Devices->Sounds
Check whether the sound scheme selected is "NO SOUNDS"
Change it to WINDOWS DEFAULT to get your startup and shutdown sounds back
cheers
techtronic is offline
Old 08-06-2007, 12:27 PM   #3 (permalink)
CA50's Avatar
Thanks 4 ur answer, but this didn`t solve my pro. My pc is still muted
| Nokia 2700c |
CA50 is offline
HELP! MY PC HAS TURNED MUTE! mandar5 QnA (read only) 5 20-02-2006 03:14 PM
