Old 07-06-2007, 06:03 PM   #1 (permalink)
Thumbs down Suggest Processor and motherboard combination
Hi guys.... wana gofor a dual core... intended for video editing and dubbing... i`m into serial dubbing and editing... I have a new Nvidia 7500Gt PCI-E... wana get a gud combination of motherboard and core 2 Duo processor... suggest best combination and pricing... thinking of E6600...is it ryt choice...plzzz suggest......
princedmedia is offline
Old 07-06-2007, 06:20 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Suggest Processor and motherboard combination
Please tell us your budget, that helps in entire decision
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 07-06-2007, 09:22 PM   #3 (permalink)
i`m not concerned about budget pal... just a processor core 2 duo and a motherboard for video editing and audio dubbing.... say atleast 20k.. plss reply back my friend... asap.... thnx
Old 07-06-2007, 09:42 PM   #4 (permalink)
Host4Cheap.org
Core 2 Duo E6600 and Asus P5B deluxe should be in budgte and good combination in my opinion
Old 07-06-2007, 10:10 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
I would vote for P5N-E SLi as its cheaper than the p5b and i dont thing P5B is better than it ?? or is it ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-06-2007, 07:36 PM   #6 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Please answer me...
Which editing software you are using?
Are you using the same system for Audio Dubbing & Video Editing? If yes, do you interested in Fanless Design Motherboards?
Why do you need a SLI motherboard? No editing sw make advantage of SLI configuration! Do you play games?
Are you going to overclock? Do you planned to upgrade to Vista in near future? or even any 64bit Operating system?
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Old 14-06-2007, 03:41 PM   #7 (permalink)
I M BACK , WITH A BANG
saggygenius's Avatar
aha atleast 20K. . .
good budget
Go for the intel E6700 for 16K,
& ASUS P5N E SLi for 7K,
thats a gr8 CPU for your editing needs,
also go with atleast 1*2 GB DDR2 667mhz ram which would copst you 3800rs,
My Greatness Cannot be Expressed in Terms Of normal Word's,It Requires a Compiler
-By saggygenius
saggygenius is offline
motherbord and processor combination problem the.kaushik Hardware Q&A 6 16-03-2007 05:19 PM
Best AMD Processor & MoBo Combination for my new PC? Ramstrong Hardware Q&A 20 27-10-2006 06:50 PM
Need a Good Processor & MotherBoard Combination vinyas Hardware Q&A 12 15-05-2006 10:50 PM
Best Mobo+Processor combination for AMD... White`Knight Hardware Q&A 30 18-03-2006 12:28 PM
processor and MOBO combination sav_more CPU / Motherboards 17 18-08-2004 02:38 AM
