Old 07-06-2007, 01:03 PM   #1 (permalink)
Stareable.com
Default PC doesn't boot after maintenance.
Hi,
I have a 3.02 Ghz P4 HT and D915GAV mobo. The CPU temperature was at 92 so i cleaned the fans and applied Artic Silver as usual. I do it every 4 months or so, the fan gets all dusty. But this time, after fitting everything, the PC is not booting, i checked the RAM, they are fine, i tried another power supply, still it doesn't boot. The problem lies in the motherboard or the processor. But i can't figure out which.
After i power on the system, the 3 leds on the keyboard blink once and then they are off. Nothing happens and the fan keeps spinning. Wat i observed was the keyboard lights blink immediately. Normally they blink after say 3 seconds. Wat can be the problem?
risqer is offline
Old 07-06-2007, 01:21 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: PC doesn't boot after maintenance.
check whether some dust particles entered ur processor seating space.
praka123 is offline
Old 07-06-2007, 01:27 PM   #3 (permalink)
Stareable.com
no dust particles, i cleaned it again, still it doesn't boot
risqer is offline
Old 07-06-2007, 01:35 PM   #4 (permalink)
praka123's Avatar
I faced the same problem of not getting system working after a clean up including a Vaccum CLeaner blower used from a distance to keep the dirt blowed off.anyways the system stops working while processor is running.lately i got my mobo replaced as it is under warranty.not to fret you but do check any possibilty for mobo to get working
praka123 is offline
Tips on Mobile Maintenance Gigacore Mobiles and Tablets 6 18-04-2007 12:32 AM
Maintenance of Server and Clients in a network sainit Networking 3 28-06-2006 02:15 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
