Old 07-06-2007, 10:17 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default pc slows down !!!
i m using
AMD 3200
MSI K8
512 + 256 trancend RAM
80 GB hitachi + 80 GB samsung 7200 rpm HDD
Win XP sp2
recently my sytem drastically slows down when i m copying something especially from a CD or a DVD to my HD. even de song playin in winamp dosent run smoothly... is it a virus?
i checked my sys temp using 'speed fan' its avg is always around 45 C, it it fine.
plez hepl me
what sud i do???
ankushkool is offline
Old 07-06-2007, 11:45 AM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: pc slows down !!!
Disable your antivirus when copying files. Since winamp also skips audio this means CPU usage is going high.
about.me/gxsaurav
gxsaurav is offline
Old 07-06-2007, 02:53 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can also check following tut to speed up ur windows:
MASTER TUTORIAL: Make Your Windows XP Super Fast !!!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-06-2007, 08:17 PM   #4 (permalink)
ankushkool's Avatar
i hav tried everythin... disabled my antivirus, used every possible soft like 'norton utilities', 'tune-up', 'pc-boost' but no results. i even close any application runnin in background but dosent help.
is it a virus...
or is there some hardware problem????
Old 10-06-2007, 01:09 PM   #5 (permalink)
காத
try replacing your IDE cables of both hard disk and dvd drive...
it worked for me sometime ago..
but i m sure it isnt a virus.. it must be a hardware problem
Regards,
Prabhagaran
Prabhagaran is offline
Old 10-06-2007, 01:17 PM   #6 (permalink)
Stay Silent!
enticer86's Avatar
my funda whn it slows down : format n reinstal.
takes max 1 hour to restore the pc bak to the original state [includes installin windows + all softs n drivers]...stil this 1 hour is a gud CAPITAL INVESTMNT to reap REVENUE INCOMES in terms of fast speed
Guys dont b confused by my lingo- m a finance geek as well!
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 10-06-2007, 01:21 PM   #7 (permalink)
digit i am thinking's Avatar
I think it the prob. of DMA.
Activate it from nero tool kit.
digit i am thinking is offline
Old 11-06-2007, 06:28 PM   #8 (permalink)
ankushkool's Avatar
how 2 avtivate DMA???
Old 13-06-2007, 01:08 AM   #9 (permalink)
ankushkool's Avatar
sm1 plz reply..... i tried but cudnt find hw 2 activate dma
Old 13-06-2007, 01:39 AM   #10 (permalink)
Commander in Chief
QwertyManiac's Avatar
You can try this tool ..
It could possibly be an infection .. Just tell us if some particular process in the task manager is high up on CPU usage. Oh and better run a scan ..
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-06-2007, 01:59 AM   #11 (permalink)
ankushkool's Avatar
the problem occurs even while copyin frm hardisk 2 hdd
Old 18-06-2007, 08:48 AM   #12 (permalink)
I suffer the same problem of 80-100% CPU usage when coping images from CF card, I cant do any other work at that time & I wonder why would copying 500 files take that amount of cpu usage?
I posted earlier but could not find any solution.
It happens both on my desktop & laptop
ranjan2001 is offline
Old 23-06-2007, 12:13 AM   #13 (permalink)
Is actually a real word..
reinstall windows WITHOUT norton and then see. Norton is bad, trust me!!
Liggy is offline
Old 25-06-2007, 01:04 PM   #14 (permalink)
ankushkool's Avatar
nothings workin guys
looks like re-installin windows isde only option.
Old 26-06-2007, 11:48 PM   #15 (permalink)
Jai Suresh
lywyre's Avatar
Run this program (http://download.sysinternals.com/Fil...ssExplorer.zip) and post a screenshot here. May be we could identify some unwanted process that should not be running.
lywyre is offline
Old 27-06-2007, 01:07 AM   #16 (permalink)
TechTin.com
ravi_9793's Avatar
Do regular........
1) Disk clean up
2) Registry cleaner...try ccleaner or tune up
3)Disk defragment once in a moth.
ravi_9793 is offline
Old 27-06-2007, 03:51 AM   #17 (permalink)
Just format and reinstall windows or ne othr os ... it will defintly wrk dude
and use avsat anti virus ... nd do clean ur cookies,histry,temp folder check HD for bad sectors nd defrag ur HD monthly
MY TECH BLOG - www.technicaltricks.blogspot.com
Last edited by nobody.is.perfect.eME; 27-06-2007 at 03:51 AM. Reason: Automerged Doublepost
nobody.is.perfect.eME is offline
Old 28-06-2007, 01:08 AM   #18 (permalink)
pulled this from ms website "For repeated DMA errors. Windows XP will turn off DMA mode for a device after encountering certain errors during data transfer operations. If more that six DMA transfer timeouts occur, Windows will turn off DMA and use only PIO mode on that device.
In this case, the user cannot turn on DMA for this device. The only option for the user who wants to enable DMA mode is to uninstall and reinstall the device."
so yeah would suggest a reinstall of windows, or if you want to waste more time you can try to uninstall/reinstall the drivers but I think you said you tried that before. or if you want to try and set the DMA follow ms's solution "
To enable DMA mode using the Device Manager
1.
Open Device Manager.
2.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
3.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
4.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
•Change the selection from "DMA if available" to PIO only, and click OK.
•Then repeat the steps above to change the selection to DMA if Available
***info taken from the microsoft website ( http://www.microsoft.com/whdc/device...e/IDE-DMA.mspx )
Liggy is offline
DOS Application slows in XP gopi_vbboy Software Q&A 10 04-03-2007 07:51 PM
What slows XP booting from the following? ranjan2001 Software Q&A 6 20-02-2007 11:45 PM
What really slows Windows down !? anandk Software Q&A 21 13-10-2006 01:37 PM
Copying slows down system shwetanshu QnA (read only) 13 18-08-2005 05:00 AM
Kaspersky slows down PC? navjotjsingh QnA (read only) 18 03-06-2005 04:27 PM
