Old 05-06-2007, 08:04 PM   #1 (permalink)
காத
Unhappy Hi Speed USB device can Perform Better
Hello Gentlemen,
I have a P4 2.8GHz on Intel D865GBF motherboard. I recently plugged into my USB pin, a hard disk that was connected to an IDE to USB convertor. But my PC said that the device can perform faster if plugged into a hi speed usb port. I tried it with all the ports on the motherboard, but the same message displayed. And the device(hard disk) did not show up in "My Computer". ALso an error message stated "Windows does not recognise the device. It may be malfunctioning"
MAy i know whats the problem?? Does my motherboard support USB 2.0 or not?? Should I buy a USB 2.0 PCI board or what??
Kindly help me please..
Regards,
Prabhagaran
Prabhagaran is offline
Old 05-06-2007, 11:02 PM   #2 (permalink)
ashfame's Avatar
Default Re: Hi Speed USB device can Perform Better
install usb2.0 drivers for ur mobo
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 06-06-2007, 02:06 AM   #3 (permalink)
Mclaren F1 Long tail
aneesh kalra's Avatar
Go to bios and change usb from full speed to hi speed.
Computers are like air conditioners. They work fine until you start opening windows.
aneesh kalra is offline
Old 06-06-2007, 09:36 PM   #4 (permalink)
காத
Thanks for your replies...
I ve searched for usb2.0 driver in intel website. but couldnt fine one in my mobo downloads list..
Also, I have already changed that hi speed BIOS setting for USB..
Any other options??
Regards,
Prabhagaran
which UPS will perform my needs ? Techie_Geek QnA (read only) 38 19-02-2006 01:25 PM
Hi-Speed USB Device - Help chaitanya_vmk Peripherals 5 15-02-2006 11:41 AM
About my System Perform mahesu_87 QnA (read only) 2 11-11-2005 05:34 PM
Please help!!!!!!!!! -Could not perform end of disc at once libinbenny QnA (read only) 4 05-03-2005 07:23 PM
