Old 05-06-2007, 05:30 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Question What is wrong with the boot sector?
This is really a strange problem which is happening on my friend's PC. I don't know the perfect configuration, but I think only the hard disk part matters now. My friend had to reinstall Windows recently. Since this was a reinstall, GRUB was overwritten and I wanted to reinstall GRUB. This didn't happen as SuSE constantly kept showing that it couldn't install. I thought something had gone bad with the CDs, but it wasnt' as I had installed GRUB just 2 days back on my system with the same CD. Now, due to some problem, Windows had to be reinstalled (again ) To our surprise, we find that the files deleted in the Recycle Bin is intact even after formatting (both quick and complete) While checking with the defragmanter, we saw that the files were not at all removed, but it showed contigous files. It even started defragmenting!!!! Doing a chkdsk also didn't show any bad sectors or bad files. I have reinstalled Windows 3 times and the same thing is happening. Once even deleting the primary partition!!!!! GRUB is also not being written to the MBR due this problem. What exactly is the problem and how to fix it?
Want to make this world a better place? Then, start seeding and don't be just a leecher
phreak0ut is offline
Old 05-06-2007, 06:42 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Smile Re: What is wrong with the boot sector?
If ur Master Boot Record is got problem,U can try installing grub on /boot partn(boot sector of the partn).make sure MBR is not available.may be make the /boot partn active.
Installing GRUB natively
http://www.gnu.org/software/grub/man...-natively.html
praka123 is offline
Old 06-06-2007, 12:00 PM   #3 (permalink)
phreak0ut's Avatar
Default Re: What is wrong with the boot sector?
@Praka- Yeah, that is an alternative, but I want a complete fix to this problem so that Windows doesn't act up as well. I'll check that link. Thanks. Anymore suggestion guys?
Old 11-06-2007, 06:05 PM   #4 (permalink)
phreak0ut's Avatar
Bump!
Old 11-06-2007, 11:45 PM   #5 (permalink)
praka123's Avatar
there is something u can do if u got a backup is -low level formatting may be it will resolve?
praka123 is offline
Old 12-06-2007, 08:10 AM   #6 (permalink)
phreak0ut's Avatar
Backup is the problem. She's got GBs of data to backup. After that, low level format. I really hope it will fix the problem.
Boot Sector problems saurabh.sauron Open Source 2 07-11-2006 11:27 AM
Bad Sector ????? Problem ashishsingh_bhatia Hardware Q&A 6 03-02-2006 10:58 PM
Bad Sector mahesu_87 QnA (read only) 7 07-07-2005 09:26 AM
Boot Sector gone bad dilip281 Software Q&A 6 06-04-2005 02:25 AM
boot sector virus quark Software Q&A 4 21-12-2004 09:54 AM
