| Forum |
#1 (permalink) |
GUNNING DOWN TEAMS
Both are transcend rams... But 512 Mb is 2.5-3-3 and 1gb is 3-3-3... first time i inserted 1 gb ram ( its second hand) it made my sytem unstable... the with 512 mb ram it hanged..but agian when i had it booted with just 1 gb ram after few restarts it was okay.... Now i wanna use both rams...any solution... How can i check ram ( 1 gb one)??? other than memtest?? Reply fast else i have to return that ram.... BTW my mobo is MSI rs 480 BIOS - 6.00 PG
The moment U stop learning ......u stop improving Last edited by wizrulz; 04-06-2007 at 12:19 AM. |
#2 (permalink) |
SNIST Screamer !!
i dunno the exact method to make both work....but there is an option in the BIOS to under clock memory latencies...try tht
http://snistscreamers.blogspot.com/ http://insidevoidmain.blogspot.com/ SNIST-Blog: the Voice of SNIST... http://www.snistblog.com/ |
#4 (permalink) |
Try me
well check your power supply..
and with that also change the ports of RAM.. insertthe 1gb one in the first slot and the other in third slot(only in MSI RS48xMx series)
Forum rules: http://www.thinkdigit.com/forum/announcement.php?f=3 Blog at : http://thecomputernext.com/blog |
#6 (permalink) |
GUNNING DOWN TEAMS
@shantanu
I am sure no problem with power supply as the individual stick work ..only problem is making them work togteher..... @ assassin Thats the point ....will after setting 3-3-3 latency ....will 512 mb ram which is 2.5-3-3 work?? and if does then which ram should be palced first 512mb or 1gb????
The moment U stop learning ......u stop improving |
#7 (permalink) |
^^^ both sticks sud work @ 3-3-3.if not then try 2.5-3-3.if both timings dont work then 1st underclk both ram so as to match their timings.
the same thing happened to me when i tried to run 2 1GB DDr2 sticks,ona a 533MHz and the other a 667MHz.had to manually adjust ram timings i bios. |
#8 (permalink) | |
GUNNING DOWN TEAMS
how to underclk them or one of them???
#10 (permalink) |
@wizrulz did u 1st try changinh the timings??
as for underclking the ram,enter the bios and search for the option where it shows the ram clk freq.enter that sub menu and and select 266Mhz and then adjust the timings.its a trial & error method but thats the only way to go. |
#11 (permalink) |
GUNNING DOWN TEAMS
Check out the images i have attached.....adn explian it.....
I have kept 1gb in slot 1 and 512mb in slot 2...made latency as 2.5..... But in cpu z it showing 2.5 for 1gb and 2 for 512mb..also speed is shown 166Mhz???
#12 (permalink) |
The SPD tab in CPU-Z shows the rated speeds for the RAM modules and not the actual speeds they are running at. In your case, its showing the rated timings @166 as well as @200 MHz.
The actual timings at which the memory is running is displayed in the Memory tab (In your case - 2.5-3-3-7). Since the 1GB module is not rated to run at these speeds, thats your problem. You need to manually adjust the timings through your BIOS. If thats not possible, try using nTune.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA |
#13 (permalink) |
GUNNING DOWN TEAMS
NVIDIA Ntune u mean.....but i have ATI based mobo.....so will it create problems???
anything similar to NTUNE???? for msi rs 480
The moment U stop learning ......u stop improving Last edited by wizrulz; 06-06-2007 at 12:39 PM. |
#14 (permalink) |
Try me
Ntune only works om NVIDIA Based Motherboards (nvidia chipset)
there are many tweak utilities on www.guru3d.com check among them. and install 1gb in first place..
#15 (permalink) |
Sorry, didn't realize you had an ATI mobo. Your driver CD itself might have some sort of utility bundled by MSI. Just check it out.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help with SC:DOUBLE AGENT | ratzee199 | Gamerz | 11 | 15-05-2007 12:37 PM |
| Double Bandwidth ??????? | ashu_dps | Software Q&A | 5 | 08-02-2007 12:10 PM |
| Right double click | nil_3 | QnA (read only) | 10 | 31-12-2005 04:29 AM |
| Fedora Core 4 installed ...... trouble trouble trouble... | iinfi | Open Source | 19 | 12-10-2005 06:03 PM |
| double trouble with yahoo messenger? | snehal_prabhu | QnA (read only) | 4 | 18-11-2004 09:29 PM |
