Old 03-06-2007, 10:45 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Exclamation Installation Problem XP SP2
Hi Forum Members, I need your help.
My System config is:-
1. MSI Mainboard with Intel 845GE ICH4 chipset Model MS-6714 ver 5.0
(845GEM-L)
2. Processor : Intel P-4 2.4 Ghz (133*1
3. RAM : 1) 128 MB DDR(266) * 1
2) 258 MB DDR(not known) * 1
4. HDD : ATA 40 GB
5. BIOS : Award phonix BIOS Ver 7.3 dated 14/04/2004
6. Present OS = Windows XP with out Service Pack (Runs super fine in my
system)
Now the problem is I cannot install/upgrade XP SP1/SP2 in my system.
During Installation sequences are:
1. Compiability check = OK
2. copying required file for installation = OK
3. REstarts system and start XP installation = OK
4. Restarts system with Win XP logo and the system hangs up.
After trying several times with different XP SP2 CD same things happen.
I also tried to solve the problem by replacing the RAM, but in vain.
If any guy have any solution for the said problem please help me.
skghosh44 is offline
Old 04-06-2007, 08:50 AM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: Installation Problem XP SP2
why dont u patch ur current OS with the SP2
vijay_7287 is offline
Old 05-06-2007, 12:39 AM   #3 (permalink)
ECE0105's Avatar
Are you getting this when updating the OS with SP2 or are you getting it when you are trying to install Windows XP+SP2 ????
In both cases, try a clean install... i.e. Format the Partition and install Windows XP and immediately install SP2 or Format the partition and install Win XP+SP2
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always....
ECE0105 is offline
Old 05-06-2007, 12:55 AM   #4 (permalink)
Try me
shantanu's Avatar
just use the method to integrate the SP2 setup in your CD.. then install windows XP again.. it will do.. the problem is coming coz of some drivers corruption..
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 05-06-2007, 01:21 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
If I am not mistaking and if it is the same problem which u have discussed early in the forum and with me in PM, then i think u have done that Integration part which didnt help u...
So if it is that old issue then, See try changing the Hardware now !!! RAM would b the one i would suggest, try chaning with any frnds or any one else's RAM... also Upgrade the BIOS if any update available !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 05-06-2007, 08:42 PM   #6 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Friends,
Clean Install, upgrade, other HDD, fresh XP CD, CMOS clear Data, BIOS to
factory setting, format of HDD every thing has done, but the problem is same.
Only thing is left to replace RAM with new one or from other system.
Another thing is upgradation of BIOs from 7.3 to 7.4.
But BIOS flashing is not possible in my system, becasue my flopy drive is not
working properly. Always MSG appears as "This disk is not formated, Do you
want to format it ?" If I click yes smg appears "this this cannot be formated".
Tell friends any solution. Is BIOS update possible from CD.
Old 07-06-2007, 09:03 AM   #7 (permalink)
mithun_mrg's Avatar
Boot To Safe Mode To Check Actually Where It Is Getting Stoping
I Think A Bios Update Will Solve The Problem
mithun_mrg is offline
Old 09-06-2007, 08:23 PM   #8 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Your opinion may be correct. I have already downloaded the latest BIOS. But I am unable to flash the BIOS because there is some problem in my floppy drive. I have contacted with MSI-INDIA Support Centre, they have sugestted me to upgrade the power supply from 250W to above 300w. Now I have arrange the same and have to try.
Win XP SP-II Installation Problem skghosh44 Hardware Q&A 28 07-02-2008 09:35 PM
Win XP SP-II installation Problem skghosh44 Hardware Q&A 1 15-04-2007 07:38 PM
XP Installation problem sknowonweb Software Q&A 8 12-11-2005 12:34 AM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
Installation problem aathif QnA (read only) 2 15-02-2005 08:29 PM
