Old 03-06-2007, 10:38 PM   #1 (permalink)
Default Preformace difference between PATA & SATA
I am find a performance approx. 20% in performace difference between PATA & SATA Hard disk in case of Dual Core and C2D Processors. I request Forum Members to pass Remarks & important to upgrade knowledge.
gcbeldar is offline
Old 04-06-2007, 08:47 AM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: Preformace difference between PATA & SATA
20% sounds an exaggeration
but there will be a differrence....and it is not specific for dualcores
vijay_7287 is offline
Old 05-06-2007, 01:04 AM   #3 (permalink)
Try me
shantanu's Avatar
the HDD transfer rate is not dependent on processors..
well PATA and SATA are two very different technologies.. SEAGATE gave a 20 minute video on this issue.. even the SATA II does not mean that it will have a 300 mb/s transfer rate.. there are many factors .. but SATA is much much faster then PATA..
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 05-06-2007, 01:25 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
I have Both with C2D !!! SATA-II, SATA and PATA, only thing which i noticed that placing the page file on SATA-II (cosidring that OS in a Diffrente Drive) give a little fast system
My Config, C2D E6600 / P5E-E SLi / 3GB DDR-II
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Difference between SATA & PATA Disks h_kunte Hardware Q&A 14 29-11-2005 04:13 PM
what is the basic difference between PATA, SATA other HDD taken QnA (read only) 1 09-07-2005 06:03 PM
Sata or Pata ...... What is this. godsownman QnA (read only) 19 10-06-2005 06:41 PM
PATA and SATA tushar_novice QnA (read only) 8 27-03-2005 10:42 AM
SATA YA PATA nishantv2003 QnA (read only) 19 20-10-2004 11:12 AM
