Old 03-06-2007, 09:14 PM   #1 (permalink)
Default Usb Not Working
my friends USB port is not working
what can be done?
can a new USB port installed in the PCI SLOT?
rounit is offline
Old 03-06-2007, 10:04 PM   #2 (permalink)
Cool G5's Avatar
Arrow Re: Usb Not Working
You can get a Usb card inserted in pci slot.
Before that check the usb cable connections.
Cool G5 is offline
Old 04-06-2007, 08:51 AM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: Usb Not Working
after u check cables...try uninstalling the USB root hub frm the OS
it will be reinstalled after a restart....
vijay_7287 is offline
Old 04-06-2007, 09:25 AM   #4 (permalink)
Before that check the usb cable connections.????????
and where will i get the usb root hub in OS?
plz expalin
rounit is offline
Old 04-06-2007, 09:52 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
start-->>right click My COmputer-->> properties-->>hardware-->>Device Manager-->>-expand the branch Universal Serial Bus Controller
If the status device is not known OR not working, update the driver.
If you cannot see any usb port...than check the wires(also power cables) inside the cabinet.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
IE 6 not working DeSmOnD dAvId Software Q&A 8 06-02-2007 12:59 AM
** Working/Not-Working Programs with VISTA ** PrinceHeart Software Q&A 42 01-10-2006 04:01 PM
Ram not working??? LegendKiller QnA (read only) 6 22-12-2005 03:42 PM
USB and LAN nt working on XP sourcecode Networking 1 20-12-2005 07:04 PM
DVD-ROM AND CD-ROM NOT WORKING VERY OFTEN kumarn_2004 QnA (read only) 1 18-04-2005 02:26 AM
