| Forum |
#1 (permalink) |
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness Think of your 3 best friends. If they are OK, then it's YOU |
#2 (permalink) |
Today's integrtated audio comes with good fidelity in terms of music reproduction. The real need for a good audio card comes when there's a need to produce (record) quality music.
The good sound cards come with a lot of features to minimise noise levels etc. For those who aspire to be musicians and composers, a sound card is almost inevitable.
Sony Xperia Neo V - Review and Discussion Thread: http://www.thinkdigit.com/forum/mobi...ml#post1520514 |
#3 (permalink) |
THANX:-P Got ur point dude. I had once used Fruity Loops Studio and noticed dat there was reduced latency in the processing of sound with my cmi8738 than my onboard sound
This is a sincere question to all u music lovers and audiophiles out there who swear by there expensive sound systems Wat i wanna know is dat is it worth buying a creative audigy series or even better sound card for simply listening to 128 kbps ,or for dat matter ,320 kbps, mp3 .ALso i wud like to know whether will the sound qaulity b considerably better if i replace my creative sbs-370 2.1 speaker set with an Altec Lansing ATP3 2.1 set
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness Think of your 3 best friends. If they are OK, then it's YOU Last edited by pushkaraj; 03-06-2007 at 09:03 PM. |
#4 (permalink) | |
V.Prem Kumar |
#5 (permalink) |
dá ûnrêäl Kiñg
use this little player which will give better sound in the same hardware for mp3's.Adjust the eq to rock and turn off auto amp.This player is considered as the best by audophiles around the world.
http://un4seen.com/
My Stomach pains http://tinyurl.com/32jj4m |
#6 (permalink) |
Still Shining!
Creative will come no-where near the ATP3 in perfomance. The bass and treble clarity is perfect for the Altec Lansing in its range.
And for listening to mp3s be it 128 or 320 kbps, onboard audio is more than enough. Make sure the onboard is realtek and not Sigmatel or soundmax.
Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB Nokia N86 8MP |
#7 (permalink) |
Hey cyberboy_kerala, Tried and tested xmplay as suggested by u. Trust me dude, i did not find much diff between dat player and wmp11, atleast on my config: CMI8738 sound card + Creative sbs-370 2.1 speakers
Anyway thanx for suggesting me dat player coz it comes in an amazingly small size- JUST 300 kb APPROX- and givin the same performance as dat of wmp11. Must say, great technology goes behind the making of such a light weight player. I am truly amazed. Probably by installing their bass addon, i will get a better bass reproduction And lucky_star, thanx for ur reply. By the way,hav u any idea whether is Altec Lansing MX5021 "REALLY" better than ATP3 ,given its high price(7900 approx)I hav kept my subwoofer on the lower side of my computer trolly beside the cabinet. So will the vibrations caused by it affect the cabinet in anyway?
#8 (permalink) | |
dá ûnrêäl Kiñg
I was using wmp11+dfx even though wmp11 sounds good,xmplay feels better for wide variety of music.
#9 (permalink) |
Dreamweaver
If u want High Definition Audio Quality u need a soundcard.
Advantage: The onboard audio will use system's RAM for processing the audio. But the Soundcard will have a builtin RAM for processing the sound. Thus will improve the system performance without giving much workload on RAM. It is just like a Graphic Card does.
Today's noobs are tomorrow's geeks. Don't make fun of them.. encourage them. - Gigacore Follow me on twitter.com/gigacore |
#10 (permalink) |
Still Shining!
you will notice little or no perfomance difference with a sound card installed. It doesn't need too much RAM. It does the same work which an MP3 player does. Nothing else. Can't compare with the capability and workload of a graphics card.
@ Puskaraj. Dude, you want too spend 7900 bucks on a 2.1? If you can spend that much then go for a 5.1 model. MX5021 is superb. additionally it has got remote and THX certification and a very big bass driver. That's why its overtly priced. But if you are looking for a 2.1 from Altec, then I would say, go for ATP3. It won't dissappoint you.
#11 (permalink) |
Thanx
As for lucky_star, i think he is right. Can't compare the graphics card's workload and capability with dat of a sound card. But then in certain situations, like the one mentioned above, the sound card plays a significant role So to conclude, probably for simply listening to good quality music, a combination of One of my questions has been left unanswered: I hav kept my subwoofer on the lower side of my computer trolly beside the cabinet. So will the vibrations caused by it affect the cpu's working in anyway?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness Think of your 3 best friends. If they are OK, then it's YOU Last edited by pushkaraj; 04-06-2007 at 12:49 PM. |
#12 (permalink) | |||
And about comparing sound cards , u can do that too .. for example , u can;t expect the Creative SB Live 24 bit to be as good as a Creative XFi .. lol .. Also , for any onboard user , u can benchmark ur onborad sound using this : http://audio.rightmark.org/products/rm3ds.shtml Post back some results in u deem so .. I'd really like to see and onboard solution keeping the CPU usage down below 0.5% usaing 64 channel at 96 KHz output ... Last edited by deathvirus_me; 04-06-2007 at 01:45 PM. |
#13 (permalink) | |||
#15 (permalink) | ||
..Also , i'm not really in WMP .. For Winamp , use AudioburstFX ... put the settings to the max ur card supports , and u'll be surprised urself ... I use it along with "Acoustic" Audio effect , and the sound experience is awesome .. |
#16 (permalink) |
Shifted from a Creative 5.1 live to a Audigy PLatinum Pro ..... theres a HUGEEE difference .....
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!! |
#17 (permalink) |
OK deathvirus_me. i hav attached 2 screenshots of my onboard realtek and cmi8738 sound card 3d studio test results.
Will check out both DFX and AudioburstFX Hey thrash_metal, wat is the cost of Audigy Platinum Pro?
#18 (permalink) | ||
Still Shining!
CMSS 3D is really a goood feature in creative cards. I have felt the difference.
If you wanna buy a card then buy the audigy series or the X-Fi series. and mix it with a 5.1 speaker system like the inspire 5.1 or anything from altec, and you will bring a whole theatre into your house. Quote:
#20 (permalink) | |
Still Shining!
#21 (permalink) |
Mclaren F1 Long tail
I have an altec lansing mx 5021 and belive me it is actually very good but it is more of a home theatre replacement rather than a comp. speaker replacement but still a good speaker with well pronounced highs and lows(much beterr than the atp3) although it distorts at max volume.One query do I need a thx certified soundcard for this.At presen tI run it on 865 onboard soundmax.
Computers are like air conditioners. They work fine until you start opening windows. |
#22 (permalink) | |
If u notice carefully ... while using 16 samples at 44.1 KHz , with the Realtek HD Audio , the CPU usage was 8% using EAX ... and with the CMI card , it was over 1% .. though it makes hardly any noticeable performance difference for general OS usage ... think of this : a card that lets u use maxed effect , and keeps CPU usage below 0.5% ?? PS : Why didn't u post the graph ?? |
#23 (permalink) |
Macboy
CMSS I have found reduces fidelity in the sound quality and on researching the net, it is true. Dolby ProLogic II is much better at upmixing.
As for a good soundcard, the creative soundcards don't stand a chance when compared with an Auzentech X-Meridian or even its lower counterparts. A good soundcard: - produces high signal to noise ratio - improves low quality mp3 files (X-Fi crystalizer, Auzentech has something of their own) - Reduces CPU usage - Decodes DD and DTS signals much better than a software decoder - provides for EAX sound effects in games..(5.1, 7.1) - Has the power to output/input sound at high resolutions (192Khz/24bit) You will NOT feel the difference in a blind test on an average speaker system as onboard soundcards have grown quite a bit. But plug in something good, and yes, I can tell the difference.
I'm like a bird... |
#24 (permalink) | |
da' Ťurntable ruleth
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i | | Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 | |
#25 (permalink) | |
Well , it's definitely recommended to put in a good sound card .... And , i got my Auidy 4 for just under 4k's ... its an OEM one , so it misses out some features from the Pro , but overall , its a real bang for buck
#26 (permalink) |
Macboy
^^ I've got the Audigy 2 ZS. Maybe something has improved in the Audigy 4... Acoustic effect is also my favourite...
But Creative has left us like dogs when it comes to Vista drivers.... the sound card just about works...
#27 (permalink) |
Who cares about Vista anyway ?? Plus , they said they're gonna charge for the Alchemy driver for Audigy , lol .. how long would it take to get the drivers over the net
.. Plus , why move to Vista anyway ?? The uber crappy driver support .. lol ..
#28 (permalink) |
Do I need a thx certified soundcard to run my thx certified 2.1 altec lansing mx5021.What I had heard that souncards should only be considered if one wants accurate poisitional sound from one's 5.1 speakers.
#29 (permalink) |
Got it for 14.5k ... !
@aneesh kalra : Dude THX is a very crazy certification , to have an optimum THX sound u not only need your Speakers + sound procssing + music/movies to be THX certified but also the room in which you are listning in !!! You can check the specifications (google THX)
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Hissing Sound/Disturbance Coming From Speakers/Sound Card ! | mikeon | Audio | 8 | 15-10-2006 10:37 AM |
| Ubuntu 5.10 creative vibra128 sound card -no sound | smurthygr | Open Source | 8 | 25-01-2006 11:59 PM |
| Help needed in buying a Sound Card | mako_123 | QnA (read only) | 17 | 16-07-2005 12:26 AM |
