Old 02-06-2007, 08:26 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Angry Computer Restarting again and again....
I m having Pentium 4 2.66 with Intel 945 Gcc....
512 MB DDR2..
no graphics card...
my problem is that when i start my PC, it goes till the processing bar of windows XP... and then restarts automatically....
After restarting, and after POST it says that hardware change may hav created this problem...
After that it shows if one wants to start the computer into SAFE mode or general(or watever) mode..
When SaFE mode is selected it works fine but when i select the general mode.. it restarts again...
I hav changed the Processor, Motherboard and Ram..
In the earlier system there was the same problem..
Manshahia is offline
Old 02-06-2007, 09:45 PM   #2 (permalink)
assasin's Avatar
Default Re: Computer Restarting again and again....
1> reinstall Win XP
2>update to latest BIOS
3> reset BIOS
assasin is offline
Old 02-06-2007, 11:06 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
before trying above solutions check and clean ur RAM.
n00b forever...
~Phenom~ is offline
Old 02-06-2007, 11:11 PM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
the Processor, Motherboard and RAM are new...
Replaced the keyboard and mouse and now its working fine...
can Keyboard mouse create this type of problem?
Old 02-06-2007, 11:46 PM   #5 (permalink)
assasin's Avatar
^^^ yeas if either or both of them hav a short circuit in the connecting wire.
assasin is offline
Old 03-06-2007, 02:09 AM   #6 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
ur RAM have problems
ssdivisiongermany1933 is offline
Old 04-06-2007, 07:26 PM   #7 (permalink)
clean ur RAM .....it may work fine
kiranbajpe is offline
Computer Restarting....Randomly..Plz help shyamno Hardware Q&A 9 16-04-2007 11:50 AM
Help...Computer is restarting while installing Windows XP... debaisaindian Hardware Q&A 11 11-02-2007 09:54 PM
Computer restarting...:( nilesh4u QnA (read only) 13 30-03-2006 11:44 PM
computer restarting automatically dittualex QnA (read only) 1 14-11-2005 12:44 PM
restarting pc QnA (read only) 19 05-03-2005 02:57 PM
