Old 02-06-2007, 03:59 AM   #1 (permalink)
bajaj151's Avatar
Question Intel or ??
Is it worth buying new CPU fan other than Intel one for better cooling ?If Yes,then which brand and how much it cost ?
bajaj151 is online now
Old 02-06-2007, 04:38 PM   #2 (permalink)
Default Re: Intel or ??
Dude...
Bajaj...
Post every query in a single post... Instead of we gettin into each post n givin u a reply...
Obviously yes if u're plannin to overclock n not if u're not intendin to o'clock...
There're lots available frm Zalman, Thermaltake, Thermalrite n many more...
Costs come all d way frm d cheap coolermaster to d high end zalman...
Rangin frm 750 bucks to more than 7.5k...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 03-06-2007, 09:18 AM   #3 (permalink)
bajaj151's Avatar
Originally Posted by gan12320021
Dude...
Bajaj...
ok bro..i will defintly tc of dis nxt tym...but..i thought...person who is comfortable in particular field (ques) will reply more appropriately...
But bro...thx for ur advice....
Which one is best among all above brands.....I kept my budget under 1000 /-
so...plz suggest me..according to my budget and plz.dere shuld be no noise when fan running at high speed....
Old 04-06-2007, 05:10 PM   #4 (permalink)
Budd...
Ther's no point in investin in a separ8 external cooler which's worth less than 1k...
I dun think it'd giv appreciable results...
And only coolermaster I believe has a cooler fer dat price tag...
Dun invest in a cooler if u dun wish to o'clock...
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
INTEL 865 GBF techsammy Hardware Q&A 7 27-03-2006 06:56 PM
amd or intel???? amrit1 CPU / Motherboards 2 24-03-2006 11:26 PM
Amd or Intel which 1 u will buy n why? sam8240 CPU / Motherboards 26 16-06-2005 05:53 PM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
