Old 02-06-2007, 03:57 AM   #1 (permalink)
bajaj151's Avatar
Default Modifying Cabinet !!
Tell me the ways to modify cabinet...I dont want to spend extra bucks..plz..
bajaj151 is online now
Old 02-06-2007, 12:00 PM   #2 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
Default Re: Modifying Cabinet !!
dude.. depends on ur creativity..
most common thing done..
cut out a section off ur cabby..
n replace it wid acrylic..
u can do nethin u want... keep experimenting..
spynic is offline
Old 02-06-2007, 03:10 PM   #3 (permalink)
Dats rite..
Creativity matters a lot... Dun jus cut dat side panel endin up in no good shape...
Google n find sites dat help in moddin...
Pro-modders go all d way moddin a humble cheap cabinet to get d best results; using LED or UV reactive fans... UV reactive wraps're available which may be wrapped around cables...
Fera cheap mod,
I'd suggest u to attach 2 LED fans on an acrlylic sheet; ac sheets're cheap..
1 on the sheet ajacent to the proccy so dat it blows cool air on top of the proccy-HS fan...
the 2nd fan adjacent to wher the gfx card sits...
Or a 120mm fan...
Choice's urs... Happy moddin...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 03-06-2007, 09:24 AM   #4 (permalink)
bajaj151's Avatar
well..thx for all ur suggestion...
But presently..I am using Zebronics Antibiotic Cabinet....which is already got transparent panle...so no need for cutting side panel....and it also got 3 led's fans...
Ya..I know..it all depends on creativity...but still...i want little bit of ur help in starting d modding....of my case.....
Thxxxx....
Old 05-06-2007, 12:33 AM   #5 (permalink)
shantanu's Avatar
buddy! i had that cabinet some time ago. its a very good one.. so i dont think you dont need anything extra.. well just make sure that your CPU FAN is not covered by wires and stuff.. means the air passage should be clear...
shantanu is offline
Old 11-08-2007, 11:38 PM   #6 (permalink)
bajaj151's Avatar
I bought 120 mm...led fan for my rear panel.....for the proper airflow....so i dont think.....i should worry about heating.....
I know....it all depends on my creativity but i want you to share yours....so that....i too can think....in much better way...dont worry....I will not copy yours.....
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
Old 12-08-2007, 02:35 AM   #7 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Well this is what I did to my cabby when I did had some time on my hands My PC Case modding......
Just use your creativity and try to keep it simple if its your fiirst time.
john_the_ultimate is offline
Old 13-08-2007, 05:12 PM   #8 (permalink)
Ishan's Avatar
Can I see few modified Cabinets....?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 15-08-2007, 07:23 PM   #9 (permalink)
why dont you paint ur cabinet .. u know give it a theme...like red throught with red LED's and sticks..(they do sell neon sticks right?). U can get inspiration from various sites with do it professionally.
hey guys, can the led's and neon sticks which we connect to the PC be turned of in anyway for a couple of hours. Can we like install a switch or anything like that?
sagsall4u is offline
Old 15-08-2007, 09:11 PM   #10 (permalink)
thrash_metal's Avatar
I wanted to mod mine but instead went for the antec 900
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 15-08-2007, 10:03 PM   #11 (permalink)
dOm1naTOr's Avatar
@bajaj151
get a large plane white large sticker and cut it like some flame and do some colouring using red nd yellow. Do it all over ur cab in creative way nd it sure will look pretty.
Or do some logo on the front white plane surface. U can also have some cable sleeving. But better idea is to channel the power cables from behind the mobo and its back plate. Thered be enuf room for gud airflow.
Attach some blue LEDs on inside of the front grill just avove the USB nd audio port. Stick some alluminium foil on the floor of the cab, but remember- the foil shudn't touch mobo orelse it wud burn out(not revenge ).
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 15-08-2007, 10:59 PM   #12 (permalink)
lalam's Avatar
I just yesterday cut a good hole in my cabinet! Just to give it an extra amount of air......Its nice experimenting but be careful you don't screw it like i almost did
lalam is offline
Modifying Cabinet !!! bajaj151 Hardware Q&A 1 01-05-2007 12:58 AM
modifying opera gambit Internet & WWW 15 29-05-2005 09:23 AM
