| Forum |
#1 (permalink) |
Posts: n/a
my budget is 7k or below for a mobo, so suggest some mobos within this budget having these chipsets, which are better overclockers>>>SLI or Crossfire? and does crossfire boards have an AM2 or LGA775 socket? plz answer all my queries. sheesh cant anyone help me out. Last edited by slash_89; 02-06-2007 at 09:46 AM. Reason: Automerged Doublepost |
#2 (permalink) | |
in 7K you wont get SLI nor XFire boards. There are many SLI and CF chipsets out there so its confusing to tell which one clocks well,here are some examples, SLI - 590SLI, 680i SLI, 650i SLI, NF4 SLI Crossfire - ATI RD580, Intel 975X, Intel 965 SLI boards are there for Socket 939, AM2, LGA775 Crossfire boards are there for Socket 939, AM2, LGA775. I hope this helps you. |
#3 (permalink) | |
so hw much fer d ASUS P5N-E Sli??
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630. |
#4 (permalink) |
left this forum longback
ASUS P5N 32 E SLI Intel CPU (Socket 775) 13500
@theitwares site
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#5 (permalink) | |
XFX 680i LT SLI = 9-10k Those are the cheapest SLI boards i am aware of. |
#6 (permalink) |
i suggest u go for an xfire mobo. cus at ur price range it is the best option. there is an advantage on xfire boards - it can run any 2 gfx's which support xfire irrespective of there models. sli cant do that it needs both of them as same models. but in xfre if u connect 2 they'll both run at the speed of the gfx which is a lower model.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SLI and CrossFire???????????????? | Debu_013 | Hardware Q&A | 9 | 02-01-2007 09:04 PM |
| Sli Or Crossfire? | supersaiyan | Hardware Q&A | 14 | 21-06-2006 04:59 PM |
