01-06-2007, 05:42 PM
The Devil
500VA or 650VA UPS?
My PC configuration is this:
Pentium D 820
Intel 945 mobo
1 sata HD
2 cd drives
7300gs Gfx card
2x512 MB DDR2 Ram
15" monitor
For the present config a 500VA UPS is enough. But I will upgrade the monitor to 17" and probably the Gfx card too. Then will a 500va UPS support the new config? Or will I need 650VA?
I'm going for APC and the 650VA is costly. So I will buy it only if its absolutely necessary. Kindly advice.
People having similar config and preferably APC UPS, kindly respond.
01-06-2007, 06:29 PM
Rebooting
Re: 500VA or 650VA UPS?
APC is good and higher is allways better !! but That config will run with 500 VA i think as if i can run E6600 + P5N-E SLi + 3GB + 2 DVD Burners + 17" with my 4 year old Proview 500 VA, u can rest asure APC 500 VA is good enough for ur system !! though Cold start (Monitor or Full system) may be a problem !!!
rebooting
ChotoCheeta.com
02-06-2007, 01:50 AM
I WANT MORE FPS!!
Does having extra VA increase uptime?
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
02-06-2007, 08:29 AM
Definitely.
V.Prem Kumar
02-06-2007, 01:16 PM
The Devil
Thanks!!
02-06-2007, 01:20 PM
left this forum longback
I got 500VA APC and it is overloaded if i try a manual start(without AC)..go anytime for 650VA one.
02-06-2007, 01:27 PM
The Devil
^^ I'm having simiar thoughts after seeing this site
http://www.extreme.outervision.com/p...ulatorlite.jsp
You can calculate your PSU requirement. Mine showed I need a 415W PSU excluding the monitor ofcourse. So a 500va UPS won't be enough.
02-06-2007, 04:02 PM
Nowadyas 650 is d bare min...
800 fer a high end gaming rig...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
02-06-2007, 04:38 PM
Rebooting
@praka123
@blackpearl
I have mentioned that, with 500 VA, one will face problem with Cold Start-up !! but certainly running process wont be effected !! so, if one plans to for a Cold start, then even i guss 650 VA APC wont do, as if one need to work with Cold Start then some Double Battary 650 or 800 VA is needed...
so, as blackpearl said, his has a budget problem, therefore I suggested that 500VA
and rather than VA Backup will also depend on that Battary one is using !!
@blackpearl
As i have writen already that I am running 450Watts (ColorSit) with E6600 + 3GB + P5N-E SLi + now 3 HDD (SATA-II and PATA) and 17" Monitor, even with my 4 Year old Proview apart from Cold Start-up, there is not a problem with Power Cut (Yes my battary is pretty old therefor not more than 4/5 mins backup)
rebooting
ChotoCheeta.com
02-06-2007, 06:15 PM
The Devil
The 500VA APC is Rs 2400 and the 650 VA is Rs 3600.
Thats a big difference.
I don't plan to do cold start. I just want it to run for atleast 5 min so I can safely save my work, finish a half burned CD etc. Nothing else.
@Choto Cheeta :
I may have a 15" monitor right now but I would upgrade to a 17".
Also the gfx card might change. Then will a 500va be enough. Even you have a 600va.
P.S: I have a 500W smps. Consider that as a limit. But it won't stretch that far.
One question more: What is the wattage rating of a 17" CRT monitor?
15" ones are of around 75W.
02-06-2007, 06:40 PM
my backup time with a 50O va APC is 4-5 minutes also take this is for a pc with crt monitor,router,gfx cards included running.
02-06-2007, 06:53 PM
Dreamweaver
500 VA is a good choice
02-06-2007, 08:49 PM
I think the SMPS wattage should also be given consideration, especially with 500 - 600 W and above becoming popular.
V.Prem Kumar
02-06-2007, 10:10 PM
The Devil
Whats your config?
02-06-2007, 10:30 PM
p4 HT 2.8ghz,xfx 7300 GT dual dvi ,gigabyte 915GV mobo etc etc +MT880 modem router,speakers and PSU is 400W.samtron 56v monitor too.
earlier i think i got lil more time as backup.
02-06-2007, 10:52 PM
also consider Mtech 800VA Double Battery UPS, It runs ma comp for 1/2hr.
i hav a p4,845mobo,256mb ddr,cd writer, 17"crt, woofer & printer running on the same ups.
throw anything on it n it will get power for it!
sometimes i switch on ma PC n den realize after a few mins dat i havnt switched the mains ON.
hehehe!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
03-06-2007, 01:05 PM
The Devil
^^ Whats the price of the Microtek UPS?
03-06-2007, 01:07 PM
I bought it many months back!
It was of Rs.2750
03-06-2007, 01:24 PM
#19 (permalink)
The Devil
Hmmm... not bad for 800VA. APC is damn costly man!!
Actually I don't know which UPS to trust.
03-06-2007, 11:27 PM
#20 (permalink)
Rebooting
APC u can Trust on that VA Thing
Quite honestly if u try mesureing that VA with Hardware !!! u will find, APC will b able to pass the test on delivering promissed VA rather than brand like Microtek or Proview or etc...
Its like that SMPS, u get a 400 Watts frontec or JBM type SMPS in just Rs. 250 or 300 MAX where as buy a Perx or such SMPS, same will Cost 3000 or more with those Brands
rebooting
ChotoCheeta.com
11-06-2007, 06:11 PM
#21 (permalink)
The Devil
OK. I've decided to go for an 800VA UPS. Now there are 2 brands - Microtek and Numeric. Microtek has 2 batteries so almost double backup time, while Numeric has single battery but is microprocessor controlled and has a monitoring ability through software. Looks more sophisticated.
Which should I go for?
Expecting some quick replies.
11-06-2007, 06:54 PM
#22 (permalink)
Rebooting
Between those to I vote for Microtech !!!!
though its only my personal Idea
rebooting
ChotoCheeta.com
11-06-2007, 07:02 PM
#23 (permalink)
Yeah go for Microtek!
Its good!
And there is a problem with the UPS that offers monitoring!
Sometimes a reverse current can flow to the port with which it is connected and damn there you go! LOTS OF PROBLEM
You should have a almost non-fluctuating power supply (impossible in INDIA   )
11-06-2007, 07:28 PM
#24 (permalink)
Techzilla!
my vote is for microtek double battery 800 va @ rs. 2300 instead of apc 500va @ rs.2100
amd x4 635 , Gigabyte 880 GM-UD2H, 2gb ddr3 corsair, 500 gb w.d caviar green, benq G2220hd , CM 310, CM 500w Extereme Plus , Tritton AX 720 Pro
11-06-2007, 09:59 PM
#25 (permalink)
i've a APC 500VA ups which is 3yrs old and it supports monitoring thru pc.i didnt hav any probs with that monitoring stuff.its working like a charm.
11-06-2007, 11:57 PM
#26 (permalink)
I am also thinking of buying a UPS. Im confused now. APC is obviously the best brand, but are its prices worth it? Wont a 800VA Microtek UPS be better than a 500VA APC?
Also, is there any way that when the electricity goes off, and my PC is running from backup, it shut downs automatically?
12-06-2007, 12:25 AM
#27 (permalink)
yeah u can do that only if ur ups supports monitoring thru pc
12-06-2007, 12:34 AM
#28 (permalink)
Which UPS have monitoring? Can you give model no?
12-06-2007, 10:08 AM
#29 (permalink)
The Devil
Now I'm more confused!!
Obviously, Microtek would give longer backup, but Numeric is a digital UPS whereas Microtek is an analog UPS. Which one will be more reliable?
Actually I have some very bad experiences with UPSes. Whichever I buy breaks down.  So I want to be very cautious.
12-06-2007, 11:34 AM
#30 (permalink)
^^^ go ahead and buy any APC ups and njoy peace of mind.
