Ok I am in the market for an lcd which meets the following specs
Budget 20 k
Anyhing over or 19 inch will do
A good response time -6ms or below
DVI port
Potrait mode (would highly appreciate if this is available in my budget)
Dual hinge with full swivel capabilities
If possible can i have altleast an hd ready resiolution 720p(very high priority)
Moreover also do lcd's use progressive or interlaced scanning technique
I also have to buy a sound card within the 4k budget something which supports a good signal to noise ratio@102db to suport my altec lansing mx-5021 thx cerified 2.1 speakers which presently run on 865 onboard sound(for the thx experience do u need a thx certified soundcard as well).
At present I am looking at the aoc 193p
http://reviews.cnet.com/lcd-monitors...-31756827.html
and the Benq FP92w
http://reviews.cnet.com/lcd-monitors...tag=prod.txt.1
in the lcd's
For the souncard I am looking at the creative audigy 2 series(not the value one since it is not thx cerified)
