i have a problem with bsnl mt882 adsl modem connected to my pc via a pci based INTEX (realtek rtl 8139d pci fast ethernet) adapter... i downloaded the drivers from
and then installed them.
the problem i had was that the LAN led on the router couldnt become green (connected) .. it kept being orange and i kept getting messages that network cable is unplugged, then it would become green for one second and then go to orange again...
to fix this problem i had to set my lan card to 10 mbit full duplex instead of auto setting in device manager > realtek card > advanced....
and it started to work...
what i want to know is that , is it a problem with the lan card or with the dataone modem mt882. i really need it to work with 100 mbit mode because i cant set it to 10 mbit mode in linux, and so my net is not workin in linux .
i have conneted the router to lan card with cat 5 patch cable provided by bsnl.please tell y cant i use 100 mbit mode.. if it is problem with the modem then which settings do i need to change in admin page of the modem, i tried setting settings of router to default but to no avail..
HELPP!!!
