Old 31-05-2007, 08:44 PM   #1 (permalink)
Kalyan's Avatar
Default Mobo suggestion needed... Urgent
Hi guyz...
I need a suggestion from you. I am planning to buy an AMD 5200+ or 5600+. (Or would you suggest me 4800+ instead).. Please suggest me if it is better value for money.
> I need a good mobo. Which is better Asus M2N-E or M2NPV-VM or any other mobo from any other company.. I am into gaming and programming. I need a good mobo. and I dont connect a tv tuner card to my pc(Just for your info.)
> Suggest me which ram ? (667 Mhz or 800Mhz??)
> Suggest me a good LCD Monitor. I need 17" one. what are the advantages of widescreen? Does it pose any probs? which company is better?? Samsung or viewsonic or benq?? should I go for widescreen or stick to normal ones?
> what is the cap. of the SMPS I should take? 500W or more/less?? I am planning for a gfx card if the prices go down for dx10 ones..
> Which is a better dvd writer? liteon or sony? does anyone have problems? I previously used Samsung cd writers and a dvd combi drive. But all of them are facing tray problems though the reading of disks is fine. I donot want to go for it again. Suggest me.. Liteon or Sony..
Please suggest me quickly. I am going to buy the new pc this weekend.
Kalyan is offline
Old 31-05-2007, 11:08 PM   #2 (permalink)
xsreality's Avatar
Default Re: Mobo suggestion needed... Urgent
Unless you suggest your budget, how will anybody help you?
The coldest blood runs through my veins
www.abhinavsonkar.com
xsreality is offline
Old 01-06-2007, 03:10 PM   #3 (permalink)
Kalyan's Avatar
Ok.. My budget is 35-40k. for the whole pc config. Now, I saw that The core 2duo E6300 is 7k+. Is E6400 a better choice than 5200+ or 5600+?
I received my May issue of digit yesterday(little bit late... though..) I have gone through the LCD Monitors shoot out. But I didnt find it much useful. It got me little bit confused. Suggest me a good LCD monitor 17". Tell me the advantages/disadvantages in widescreen ones. How is viewsonic 1703WB? Does AOC look promising? Which one should I go? Please suggest.. budget may vary. as I would be taking the components one by one and not all in a day. but all in a week or so. all I need is a better config in the given specs. apart from price. (I would be happy if price is quoted with the model nos.)
Now, I am just looking for a good motherboard. I am not able to decide. I need it future proof for playing games and for good programming. According to the mobo price and the LCD monitor price, I shall decide on the proccy according to my budget. Suggest the proccy if u have any ideas. Please suggest the accountability of 5200+ and 5600+ over 4800+. How would I be benifitted either way? I read in the forum that 5000+ price is not so justified over 4800+. thats why I took out 5000+.
Thanks in advance
Kalyan is offline
Suggestion on mobo neede codename_romeo Hardware Q&A 9 06-11-2006 12:38 AM
suggestion needed...urgent jack// ani QnA (read only) 6 04-05-2006 07:57 PM
Need suggestion..mobo,processor,hdd,ram Aniruddh CPU / Motherboards 5 05-06-2005 05:19 PM
Need suggestion...Mobo,Processor,Pci-e Card,laptop..??? Aniruddh CPU / Motherboards 11 28-05-2005 01:09 PM
Need Urgent Help/Suggestion: 2 HDD with FAT32 & NTFS PrinceHeart QnA (read only) 7 19-02-2005 01:08 PM
