Originally Posted by gan12320021
Hey Darky, Thanx budd...
M jus thinkin whether to lap ma new proccy M gona get-E6600( WEn m gettin it nex month  )...
Jus got 3M sand papers today...
Pl temme the grades of sheets used and did u do it manually or using some machine??? Is d overall process risky??? Hw abt lappin the heatsink as well?? By hw much is d temp decreased???
Use 600-1200-2000 Grit papers.
Here's the procedure -
1] Take a glass top
2] Take the paper and put it on glass top with tape so it doesnt move.
3] our some water on paper
4] Hold the chip and gently start rubbing it on the paper in such a fashion that you create '8' shape when you rub it on paper.I mean the motion while moving should be in 8 shape or so...bleh
5] keep doing it until the IHS is completely flat.
6] Check flatness with Razor blade.Hold it perpendicular to IHS and check the light passes through.When no light passes, the iHS is perfectly flat.
7] There is no need to Lap HS.
8] Be ready for a long and tiring session,few hours for sure
Hope this helps.
