Old 30-05-2007, 01:08 PM   #1 (permalink)
Unhappy Usb Flash Pen Drive
I am facing a peculiar problem.
I have two winxp independent desktops.
One has a USP port only at the rear. Have connected a cable to the port. A flash pen drive when connected to the cable is detected and works fine.
The other (newer) PC behaves oddly. When the same flash drive is plugged in at the USB ports in the front, PC shows 'hardware problem'. When plugged in the rear port, PC recognises the Flash Drive and it works fine. Since access is not convenient, when I plug a cable (proved and tested as 'working' in the other PC), and plug the flash pen drive into the cable, PC again shows 'hardware problem'.
It is beyond my comprehension! It is as though an electric lamp lights when plugged into a lamp power socket, but refuses to function when plugged into a socket on an extension cord in the same power point.
Please HELP.
Thanks
paragon is offline
Old 30-05-2007, 01:42 PM   #2 (permalink)
Default Re: Usb Flash Pen Drive
well, it could be that the front ports of ure cabinet r malfunctioning. maybe through the cord ure not getting enough power?
im not really sure
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 31-05-2007, 10:52 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
yep very true. or as most of the cabinets haf today, the front usb ports haf individual connectors for each pin. it maybe possible that there has been some wrong connection. just look into the manual and connect the front usb ports again.
infra_red_dude is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Flash Drive parimal Hardware Q&A 2 25-03-2007 11:31 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Diffrence between an usb pen drive & a flash pen drive? harpoon Peripherals 3 18-01-2006 11:25 PM
USB Flash Drive smash555 Peripherals 3 30-09-2005 03:53 PM
