Hello,
I purchased a new PC with the following configuration,
pentium D 2.8ghz,
1GB 667 RAM
945 Mobo
160 Gb SATA harddisk(seagate)
and used my old components like
samsung 40 gb pata drive and
samsun DVD writer
The configuration worked flawlessly for about a month,Then I had problems with my seagate harddisk.There were bad sectors in the drive(but my old harddisk was good after 3.5 years!!).
I checked for any problems and returned the hardisk to the seagate center and they replaced it with a Certified repaired harddisk.
But all of a sudden after just 2-3 days of usage the new harddisk had bad sectors.I do not know what the problem is and checked the sata controller with my friends WD harddisk.It seemd to work well.
Can any of you tell me what can be the problem.
Is there any conflict in using my old PATA and new SATA harddisk.
Also will Seagate replace this drive again for me......
thanks
Anand
