Old 29-05-2007, 01:52 PM   #1 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Which one is best among these two ?
Intel® Centrino® Duo Mobile Technology
• Intel® Core™ 2 Duo processor T5200
• 1.6 GHz , 2 MB L2 Cache, 533 MHz FSB
• 802.11a/b/g WLAN
AMD Turion™ 64 X2 Dual-Core Mobile Technology TL-60
• 2.0 GHz, Level 2 cache 1 MB, Up to 1600 MHz system bus running at AC/DC mode 35 Watt
well i have selected these two models from hp
1) HP Pavilion dv9222TX Entertainment Notebook PC (RZ899PA)
link is http://h10010.www1.hp.com/wwpc/in/en...-78223585.html
2)HP Pavilion tx1016AU Entertainment Notebook PC (RZ904PA) link is
http://h10010.www1.hp.com/wwpc/in/en...-78223651.html
i'm going 2 buy one of these two during de weekend . pls leave ur suggestions ASAP.
tnx in adv.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 29-05-2007, 05:47 PM   #2 (permalink)
ECE0105's Avatar
Default Re: Which one is best among these two ?
Except for the processor and the RAM. there is not much diff. b/w both these configs.
The AMD Soln. has more RAM and smaller screen size.
Do note that when going Branded, RAM is costlier than wat is offered by other Hardware vendors.
I wud recommend the AMD soln, cos it is lighter, more effective and better in terms of performance to the Intel combo in this case.
I also see that the OS is Vista Home Premium. Mebbe u cud try that with a Win XP Pro. (cuts down the costs as well).
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 30-05-2007, 10:28 AM   #3 (permalink)
sysfilez's Avatar
others pls comment.
sysfilez is offline
Old 30-05-2007, 04:21 PM   #4 (permalink)
What?
Ihatemyself's Avatar
What kind of pc do u want ?i mean 4 multitasking,entertainment, designing or programming.if multitasking go for intel centrino duo mobile tech
otherwise choose amd turion
Unremitting attention to horses neighing awesomeness is nothing to brag about.
Consider----------> Milking Cows.
Ihatemyself is offline
Old 31-05-2007, 03:25 PM   #5 (permalink)
sysfilez's Avatar
oh i got the second one on the list.
sysfilez is offline
Old 31-05-2007, 03:43 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
Both looks gr8, My suggestion is, Request a Memory Upgrade for the Intel Model, HP Pavilion dv9222TX Entertainment Notebook PC (RZ899PA)
Ask ur Delear that U want a 2 x 1 GB Interface, from Company, (as many dealer will suggest u to buy then go for RAm upgrade, dont do that)....
Ask him that U need HP warrenty in entire product !!!
so I say go for the Intel One with a RAM upgrade in 2GB (2x1) interface !!!!
as u have budget for buying more expensive AMD one so, i figure the RAM upgrade for Intel one will make it close to the AMD price but this config will rock over AMD one
rebooting
ChotoCheeta.com
Choto Cheeta is offline
