Old 28-05-2007, 11:07 PM   #1 (permalink)
tango_cash's Avatar
Default dvd writer not workin properly.strange problem!!!!!
hi ppl i have a sony dvd writer.
when i write a dvd with it, it shows no content i.e blank after writing.
but when i use IsoBuster to see the contents of the dvd it shows everything in it. but there are crosses in front of all the files.although when i extract a file it works well.there is no problem with that,i mean the data is there but it is not showing it.
pls help me.
here are the pics
tango_cash is offline
Old 29-05-2007, 08:37 AM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: dvd writer not workin properly. it gives blank dvd's after burning.
What speeds are you burning at ? If possible, lower the speed and then burn. Also, try changing the media. Switch to a better brand like Moser Baer (In case you're not using it already).
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 29-05-2007, 10:01 AM   #3 (permalink)
tango_cash's Avatar
i write at 12x mostly. and for the media i use orignal sony dvd's(with jewel case) dude.i don't think there is a better media out there.
should i try lens cleaning.
which lens cleaner should i use,and will it void my warranty???
i found a new thing. last night i switched off my p.c with the dvd in the drive.today when i started it the dvd was shown in the dvd drive in my computer,just like normally.and i cud play all songs and everything was working normally.but i ejected it and re inserted it and it again disappeared i.e did not show in my computer.
Old 29-05-2007, 10:17 AM   #4 (permalink)
Who
Guess Who's Back
Who's Avatar
maybe this sounds stupid but i think your wire is lose, open the CPU & try to re-instert it in the DVD drive, maybe it will fix the problem
Who is offline
Old 29-05-2007, 01:26 PM   #5 (permalink)
1337 |)00|) \m/
Possible... Try it out....
Old 29-05-2007, 05:28 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
did u write as multisession disk ?
try lowering speed while writting ..........
adjust or make default settings 2 ur nero software .......... dont make any changes .......
ax3 is offline
Old 07-06-2007, 02:58 PM   #7 (permalink)
tango_cash's Avatar
i have a 915 gav intel orignal mobo.it has only one port for parrallal ata so i have my cd writer and dvd writer connected to it. sometimes it only shows my dvd writer and not cd writer.
i think the loose wire thing is right . i will try it.
Old 07-06-2007, 03:06 PM   #8 (permalink)
CA50's Avatar
Try upgrading the firmware as it may not support the writting. U will get it on the com`s website
--CA50
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Is it a problem with the dvd's or the writer? anubhavj1 QnA (read only) 9 08-10-2008 12:34 PM
CDs Not Burning Properly. Plz Help. Skud Hardware Q&A 5 24-11-2006 03:13 PM
cd rom not workin.. anil_861 Hardware Q&A 15 08-09-2006 01:43 AM
DVD writer not working properly blacklisted Hardware Q&A 12 31-07-2006 10:40 AM
Monitor power settings not workin' properly crashuniverse QnA (read only) 8 11-09-2005 02:16 PM
