Old 29-05-2007, 02:37 AM   #1 (permalink)
Default Suggest a new PC for 28k.
I currently have a P4 1.7GHz, Intel 845 chipset, 2*128MB RAM, Sony DVD Writer, Samsung DVD ROM, 20GB HDD, 40GB HDD, 300W SMPS.
The onboard graphics of the system seem to be corrupted.
( Display gone bad! Plz help. )
So, now i am contemplating buying a new PC (except keyboard, mouse, DVD Writer in about 28K.
I have thought out some components but better suggestions are always welcome.
Processor: Intel Core2Duo E6320
Motherboard: (no idea which is best)
RAM: DDR2 1*1GB (what frequency, company shud be preferred??)
HDD: Seagate 250GB SATA2
will also keep d current 40GB HDD. Not 2 keen on RAID 0 though, coz as far as i read, it leads to better data transfer speeds, but has higher data loss risks.
Cabinet + SMPS: (wot power rating PSU may i need?)
Monitor: DELL 19" CRT (a shopkeeper quoted it at Rs3800, so it seemed a bargain to me...)
Speakers: Creative Inspire 2.1 speakers
UPS: (no idea, wot rating etc i may need)
Intended use: Internet, some gaming (NFSMW, NFSC shud run at good rates), music listening, project works for college etc, movies. Vista shud be able to run with Aero easily.
I dont know much about overclocking etc, but i am intrigued by it and may OC with STOCK COOLING. Kindly mention safe limits to which E6320 can be OCed without significant decrease in component life.
Also plz mention prices of all components tht u recommend.
Thanks a lot.
Here is what a certain vendor quoted me:
Intel E6320: 8100+tax
Intel 946 chipset: 3950+tax
Kingston 1GB DDR2@667MHz: 2400
Seagate SATA2 250GB HDD: 3150
Cabinet+SMPS: 900
UPS: APC: 2200
Are the prices fine?
(I might go in for a 17/19" CRT/TFT later. For now, i will use my 15"CRT
Creative Inspire 2.1: 1900
I did some research and found that maybe the Intel G965 chipset is better than the 946.
I need a mobo with gud onboard gfx (to run NFSMW, NFSC, Vista with Aero) and sound card. I will b using 1 SATA2 HDD, 1 old (IDE) HDD, 1 DVD ROM, 1 DVD Writer. So mobo shud hv adequate slots. + min 3-4 USB ports.
also, preferably the system shud support OCing the CPU to some extent
Total budget now: (Proccy+mobo+RAM+HDD+Cabinet+SMPS+UPS+Speakers)= 24k.
So kindly advise on a suitable rig.
Thanks
A weird thing about humans is we work till we\'re sick to get a fortune, then pay a fortune to get well again.
The road to success is always under construction.
harmik is offline
Old 29-05-2007, 06:59 AM   #2 (permalink)
Default Re: New PC for 28k.
if u not buying a garpic card tthen go for g965 and u r then go forn 946
hackers2005.3721 is offline
Old 29-05-2007, 10:01 AM   #3 (permalink)
damnthenet's Avatar
Even I have a similar situation...
A good motherboard to pair with E6300 c2d with good onboard grphs...
Please tell me one.....
Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
damnthenet is offline
Old 30-05-2007, 02:22 PM   #4 (permalink)
Hi!
This is what i finally intend to buy:
Intel Core2Duo E6320: 8400
Intel G965 chipset mobo: 5200
1GB DDR2 Kingston: 2400
250GB SATA2 HDD: 3200
ATX Cabinet: 1200
Creative Inspire 2.1: 1800
UPS: 2000
total: 24200
i dont intend to OC or set up RAID.
i will be using my old 15" CRT monitor, 40 GB (IDE) HDD, Samsung DVD ROM, Sony DVD Writer, keyboard, mouse.
will get gfx card, tft monitor, 2GB RAM in couple f months time...
Intended uses: games, movies, music, internet, office work etc..
What do think abt this config?? Are prices quoted OK?
harmik is offline
Old 30-05-2007, 02:58 PM   #5 (permalink)
Alpha Geek Banned
bikdel's Avatar
cool....but with onboard graphics u wont b able to play NFS MW n carbon...
why dont you go for an MSI mobo based on intel g965? better to buy from other brands than intel coz they have more features...
go for the same chipset.... intel g965 supports the whole line from celeron d, pentium d to core duo and core 2 duo...... also it supports the quad cores
therefore go for intel g965 based MSI mobo.....
got it dude.......
happy buying
PS: (erm ur earlier question.... i had the same prob few months ago)
bikdel is offline
