Old 27-05-2007, 08:33 PM   #1 (permalink)
Exclamation USB pen drive
hi!
I have transcend jet flash150 pen drive and i used win xp (pro sp2). My problem is that drive is not detect my system but another system detect that. I dont know what is the couse of problem, is it virus problem?
pls. help me!
digit2007 is offline
Old 27-05-2007, 09:01 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: USB pen drive
not virus problem. Did you go to device manager and try scan for hardware changes? Also try plugging in the usb drive to another port but i guess you must have tried that already. Do you have the latest drivers for your usb ports? I had a problem once and a driver update sorted it out.
Life is too short. Have fun.
ilugd is offline
Old 27-05-2007, 09:03 PM   #3 (permalink)
spice it up
kapsicum's Avatar
iin win xp usb devices r automatically detected...while u need to install drivers for the same in win98..
if u r using Winxp n u hv this problem...then u must first check your usb port with some other USB devices...like a usb mp3 player or printer or usb mouse...if these devices too doesnt work then u must check ur USB port for any dust(this is most likely) and clean the port.
kapsicum is offline
Old 28-05-2007, 05:30 PM   #4 (permalink)
ECE0105's Avatar
Uninstall the USB Root hub and do a scan for hardware or restart the computer and it would get installed.
Then try the Flash drive and it shud work fine... Otherwise, the USB ports have gone kaput!!! and u can get a PCI card that has USB ports. That'll fix it...
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 29-05-2007, 11:47 PM   #5 (permalink)
Arrow Re: USB pen drive
the problem might be Of the hub in which u r putting it into.Chang the port u r inserting in.if this doestn't solve ur prob then Check in the device manager For unknown device or some kind of yellow thing...written as unknown device.
next u can aslo do is discoonect the power supply from ur CPu,this is because due to static current may have set around ur ports.
the last thing u can do is try some other USB components
kushals is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
=> XP installed on D: drive, How can i change to C: drive? kool Software Q&A 1 15-04-2005 02:10 AM
