Old 27-05-2007, 05:59 PM   #1 (permalink)
"The Gentleman"
vish786's Avatar
Post which UPS to buy
i want to buy a ups and my budget is 2000... which one should i buy.
i want a good ups... mostly i am thinkin of buying APC, how is it???
my cpu and Dell's monitor and 4.1 woofer sound system consumes lot of power... so even if the power goes off.. the system should not restart.
is APC good for this... and i want a backup in range of 10 - 30 minute... tats it.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 27-05-2007, 06:04 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: which UPS to buy
what's wrong with the hardware section ??
anyway on topic, APC is one of the best but i think will be little higher than 2k there is also MircoTech double Baterry UPS though I would allways prefer APC over it
u are confuse... there is lot of difference in 10mins to 30mins to get a certain 10mins Back up one needs to buy a UPS which claims it will run more than 30mins, and to get a UPS which will give certain 30mins back up, one would need havy duty UPS which claims to provide more than 45 to 55 mins back up
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 27-05-2007, 09:00 PM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
agreed. You get an APC 1 kVA UPS for Rs. 2300/- advertised as 30-40 minute backup, but in real you get only 10 minutes or so.
Life is too short. Have fun.
ilugd is offline
Old 27-05-2007, 09:34 PM   #4 (permalink)
ashfame's Avatar
i hav a Microtech 800VA Double Battery UPS dat can run ma PC for a 1/2hr.
Got it for Rs.2750 many months back!!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 27-05-2007, 11:01 PM   #5 (permalink)
My Money is for ELNOVA.Elnova is the best.
gunda_26 is offline
Old 28-05-2007, 04:25 PM   #6 (permalink)
mobilegeek's Avatar
if you get one which has 2 batteries in ur budget that will be good.
anyways APC and Elnova are good brands
mobilegeek is offline
Old 28-05-2007, 04:40 PM   #7 (permalink)
I would suggest APC as it is the best one. Also they provide very good service too!! Using it for 4 years without any problem...
But the price is definitely more than the 2K range.
sandeepk is offline
Old 28-05-2007, 10:48 PM   #8 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: which UPS to buy
thanks guys for ur replies... i hav decided to buy APC and cost is around 1900... i enquired tat it gives a backup of 20 to 30 minutes.
does anyone know wat is the price of elnova in b'lore.
- Dijkstra
vish786 is offline
Old 28-05-2007, 11:10 PM   #9 (permalink)
ilugd's Avatar
that apc is 1 kva? I think that would be 650 VA. If that is ok, go with that.
ilugd is offline
Old 29-05-2007, 02:13 AM   #10 (permalink)
mobilegeek's Avatar
just try for 1 which has two batteries
Old 21-06-2007, 04:40 PM   #11 (permalink)
slugger's Avatar
even i am planning to buy a UPS [Uninterrupted Power Supply]
my current config
AMD Athlon XP2100+
2*250GB HDD
DVD writer
512MB RAM
15" Monitor
soon to be added ATP3 2.1 speakers
can you suggest a UPS which will give me clean backup of 15 mins
I want a soln which will give a a gr8 vfm not v expensive
something within 2.5-3k range would be nice
also what is advantage of a 2 battery UPS beside the extended time of operation
slugger is offline
Old 21-06-2007, 04:46 PM   #12 (permalink)
ashfame's Avatar
guys nw my microtek 800va is troubling me.
It trips on when monitor is switched on from switched off. Earlier it was able to even start comp without power.
But now!
Wt could be da problem
Shd i try discharging da batteries once and den charging again
ashfame is offline
Old 21-06-2007, 05:43 PM   #13 (permalink)
"The Gentleman"
vish786's Avatar
But now!
how long have u been using that ups?
my current config
AMD Athlon XP2100+
2*250GB HDD
DVD writer
512MB RAM
15" Monitor
dont put ur speaker plug in ups.... if u have high end speaker... then it will require more power.... then ur backup time weill reduce... it always better not to cannot the speakers plug in UPS if speakers require heavy power load. and i would suggest u to go for APC... as many people have mentioned it.
- Dijkstra
vish786 is offline
Old 21-06-2007, 06:26 PM   #14 (permalink)
ashfame's Avatar
I bought in AUG last year and I dont think I need to change the battery b'cuz it comes with a 2yr warranty (including battery)
ashfame is offline
Old 21-06-2007, 07:26 PM   #15 (permalink)
"The Gentleman"
vish786's Avatar
if its still under warranty then u can give it just for checkup ... they will not cost and find out problem also.
- Dijkstra
vish786 is offline
Old 21-06-2007, 10:57 PM   #16 (permalink)
RiGhT HeRe RiGhT nOw
ashishnehete's Avatar
Man APC rock in case of power supply i have been using it for about an year
i have a 500V one it give the me exact 20 min of back up time
u could go for a 650V or 1 Kva and it also give the safest protection from fluctuations
ashishnehete is offline
