Old 27-05-2007, 05:31 PM   #1 (permalink)
newbee
Default problem in intelD101GGC chipset
"i have Pentium d core2duo and a ATI Xpress200 chipset but every single game is closing the older games like Mafia,Freedom fighetrs are also have this problem."
is this because i have 333mhz 512mb ddr ram.may be this ram doesnt work properly with ATI chipset or with Pentium D..wht type of ram needed to this config.my ram size is 448mb how this hapnd,now my system showing that onboard graphics ram is 128 previously it was 256mb, and Procesor temperature is around 60`celcius, complete guidance requested pls, i am not that expert computer user..
Aone is offline
Old 28-05-2007, 05:34 PM   #2 (permalink)
ECE0105's Avatar
Default Re: problem in intelD101GGC chipset
DDR 333 is perfectly compatible with D101GGC Mobo.
Go to the BIOS and change the Onboard Video memory and that shud fix problems 1 and 2. RAM shows 448, probably cos u have selected 64MB as the Video memory.
Processor temp of around 55 to 60 deg is quite normal (IMHO)...
Check the drivers of the Mobo and also the resolution.
Me havin the same mobo, but with a P4 2.8 proccy and 1GB (2x512) DDR400 RAM.
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 28-05-2007, 11:04 PM   #3 (permalink)
Thumbs up Re: problem in intelD101GGC chipset
hey i have got a complete guidance for you,
Go to the website www.passmark.com and download a tool Performence test 6.1 nw wat u hav to do is run the tool and sit back and hve a cup of coffee u can also hve colddrinks either.after ur drink the results willl be out and u will find the faulty problem of ur machine, believe me it works.
If this solves then send a cup of coffee to me.
kushals is offline
Old 29-05-2007, 10:32 PM   #4 (permalink)
ECE0105's Avatar
I don't see how a benchmarking tool helps in changing the Onboard memory size.
Nice and fast tool BTW.... Thanks for the link
ECE0105 is offline
Old 29-05-2007, 11:31 PM   #5 (permalink)
Thumbs down Re: problem in intelD101GGC chipset
Yes this tool will surely guide u step by step And give ur hardwares scores on the basis of that u can judge ur hardware faults if any.abt the onboard Graphics I dont think that in this motherboard u can config the onboard graphics manually.for Bios U can do one thing that is update
kushals is offline
Old 30-05-2007, 12:12 AM   #6 (permalink)
ECE0105's Avatar
Intel 101GGC mobo has an option in the BIOS where you can specify the Onboard Graphics memory. The values are Disabled, 64MB,128MB, and 256MB and a BIOS update is not required for that.
ECE0105 is offline
Old 01-06-2007, 02:43 PM   #7 (permalink)
newbee
Hi its me the problem guy,thanks everybody who replied. now the error is when i play almost every moderngame released from 2004, Microsoft error reporting screen comes up and game closes. i think 512ram is not enough but i get 250mb of free memory rest used by various processes, may be another 512mb stick may do the job,now my core2duo ati xpress chipset supported ram i need..can anybody tell me abt ram like frequency and all. Currently i have 333mhz 512ram.and this closing problem occurs to other programs like IE,winamp,media player etc help me 'i am from mangalore karnataka'
Aone is offline
Old 02-06-2007, 08:03 PM   #8 (permalink)
ECE0105's Avatar
Have you tried reinstalling the OS?
Cos, if a M$ Error message comes up, it probably has to do with an issue with Software, rather than HW. And, BTW, do u have a Pentium-D or a Core2Duo?
ECE0105 is offline
Old 02-06-2007, 09:56 PM   #9 (permalink)
newbee
so i will post in SW troubleshooting section and i have pentium D 2.66Ghz..
Aone is offline
problem with 102 intel chipset sbhardwaja Hardware Q&A 1 12-09-2006 06:52 PM
945 chipset pradeep QnA (read only) 3 23-12-2005 09:32 PM
ChipSet Fan Problem Max_Power QnA (read only) 5 13-12-2005 09:50 PM
sugest a good nforce chipset motherboard and amd chipset jay4u Hardware Q&A 6 14-11-2005 12:58 AM
Chipset Fan Problem doom_marine QnA (read only) 2 02-09-2005 06:18 PM
