Old 27-05-2007, 03:37 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Which motherboard sud i go for??
I hav a P4 2.66 64Bit with a VIA/SIS motherboard/Chipset...
Its not upto the mark and i want to change it...
can anyone plz help me selecting a good Mobo??
Manshahia is offline
Old 27-05-2007, 03:38 PM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: Which motherboard sud i go for??
how bout the intel 965 series !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 27-05-2007, 03:52 PM   #3 (permalink)
Oh why 965???
The nvidia 680i can even do... Or the 975....
Dude, dun joke...
He's come here fer help... Do tat....
Better go fer some 865 or 875 if its a prescott proccy...
The intel original stuff mus still be available.... Rare tho...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 28-05-2007, 01:11 AM   #4 (permalink)
Aniruddh's Avatar
yups 865 mobo r still available in de market i wud suggest urself a 865GBF intel orginal or may b 865 chipset that shud b f9 wid ur proccy!
Aniruddh is offline
Old 28-05-2007, 10:25 AM   #5 (permalink)
Gigabyte 865GSA ~2500/-
kooabs03 is offline
Old 28-05-2007, 10:44 AM   #6 (permalink)
assasin's Avatar
i'll suggest u to buya Intel 945 GCC original mobo for 3.7k or a 945 chipset based mobo then u'll be having a chance to upgrade to C2D later if u feel like.
assasin is offline
Old 28-05-2007, 12:30 PM   #7 (permalink)
Yeah dats rite.. But if its a Prescott??? He'll hav to ge fer a 865 series els ur suggestion's grt...
Old 30-05-2007, 04:59 PM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
how to find that its a prescott or something else??
Old 30-05-2007, 07:00 PM   #9 (permalink)
assasin's Avatar
i think u wanted to mean that his proccy is 478 pin one and not LGA 775.
assasin is offline
Old 31-05-2007, 02:18 AM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
ok...
My processor specs are..
Now which motherboards sud i go for??
hows asus's P5 models??
Plz give names of some best motherboards...
Thnx
Old 31-05-2007, 02:26 AM   #11 (permalink)
Originally Posted by Manshahia
ok...
Thnx
which P5 model are you talking about? P5 ranges from 4500-13900 bucks
kooabs03 is offline
Old 31-05-2007, 10:58 AM   #12 (permalink)
Resident Fanatic
Manshahia's Avatar
yeah....
i want you people to suggest a model...
the starting range wud b fine...
As i m going to buy a Laptop soon....
It will be sitting idle most of the time then...
Plz suggest some models from Asus and Intel...
thnx..
anybody there?
Old 31-05-2007, 12:09 PM   #13 (permalink)
Rebooting
Choto Cheeta's Avatar
if u dont plan to upgrade the PC in any time soon, then I would give u 2 options,
D102GGC (ATi Chip, good onbaord GRFX) under 4k (if u find it)
D965RY (x3000 GMA supporting DX10 for Vista) under 5k
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-05-2007, 02:44 PM   #14 (permalink)
Resident Fanatic
Manshahia's Avatar
ok...
i m going to sell it...
dealer says 3.5K. Is it ok.?? it is 1 year old...
I think i sud go for C2D kit...
i m going for Dual core 3.0 with 945 GCC original for 7.4K...
is it alrite??
Old 31-05-2007, 03:35 PM   #15 (permalink)
Rebooting
Aviod 945 based boards, if u have budget problem then stick to D102GGC with Dual Core 3.0... other wise think of G965 based ones... !!!
rebooting
ChotoCheeta.com
Old 31-05-2007, 03:39 PM   #16 (permalink)
Resident Fanatic
Manshahia's Avatar
wat is the problem with 945 bro??
Old 31-05-2007, 03:46 PM   #17 (permalink)
Rebooting
Well If u like certainly buy a 945, its ur PC, but as u asked for suggestion therefore i suggested what i though should be better for ur
anyway, why i say D102GGC !!
because the X200 ATi Chipset for D102GGC certainly better than 945/946 ones with with Dual Core Pentium D processor... !!
rebooting
ChotoCheeta.com
Old 31-05-2007, 04:09 PM   #18 (permalink)
Resident Fanatic
Manshahia's Avatar
bro... the delears here only deal in some popular mid-range motherboards and PC..
so there are not much option and i cant go to Chandigarh or Delhi for purchasing this... []
Old 31-05-2007, 04:13 PM   #19 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Where u live bro Come down to Chandigarh if you can....Intel 965RY sells for Rs 5200 here You should be able to find 965Ry at you place aswell
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 31-05-2007, 04:50 PM   #20 (permalink)
Resident Fanatic
Manshahia's Avatar
m from mansa dude... arnd 150 Kms away...
but dont hav enough time...
Old 31-05-2007, 04:54 PM   #21 (permalink)
Rebooting
OK.. when u dont have any option then i guess u have to go for what available... now if ur budget is 8k, think of AMD X2 sulutions... Check some price from here, http://www.theitwares.com/motherboards/motherboards.htm
an AMD X2 4400 with may be Asus M2N MX should come under ur budget !!
(Note that Prices are in that web site is atleast 10 to 15 % higher than actaul Street Price in local area !!)
rebooting
ChotoCheeta.com
Old 31-05-2007, 05:16 PM   #22 (permalink)
Resident Fanatic
Manshahia's Avatar
went for that...
P4 3.0 DC...
945 GCCr....
512 DDr2
Old 31-05-2007, 05:49 PM   #23 (permalink)
digit i am thinking's Avatar
i think u should go for 102ggc
bez it has ati graphics
or otherwise go for nvidia based
never go for 945
digit i am thinking is offline
Old 31-05-2007, 09:00 PM   #24 (permalink)
assasin's Avatar
dont go for Pentium D,they aint that good proccies,its better to go for AMD if u cant buy E4300.
assasin is offline
which is the best amd motherboard vikas_r_s Hardware Q&A 35 04-02-2006 08:10 PM
Which is the best Motherboard available??? go4saket CPU / Motherboards 2 06-10-2005 10:34 PM
Which motherboard??? bizzare_blue CPU / Motherboards 5 31-01-2005 09:36 AM
