Old 27-05-2007, 03:45 AM   #1 (permalink)
 Macboy
goobimama's Avatar
Default CoolerMaster Fan Controller
I was checking out this thing: http://www.theitdepot.com/product.ph...product_id=779
Will it work with my PC and show me all fan details and such? Where does it plug into?
I'm like a bird... :)
goobimama is offline
Old 27-05-2007, 09:45 AM   #2 (permalink)
Default Re: CoolerMaster Fan Controller
I also would like to know details about it.
I think it plugs into the CD drive slot.
V.Prem Kumar
janitha is offline
Old 27-05-2007, 11:04 AM   #3 (permalink)
Yup it fits into one of those 3.5" bays....
Its used fer h/w fan monitorin; wateve it is...
wherein d fans've an additional cable other than the pwr cable... ( Usually a single wire tat comes with brands such as Antec; ordinary coolermaster models doesn've tat!!!)
Active control.. Hence excessive sound can also be contrld if the syst isn't under load...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 27-05-2007, 01:39 PM   #4 (permalink)
 Macboy
goobimama's Avatar
I know how it works as in what it does. I also realise that it fits into the 5.25 inch drive bays?
What I want to know is how do I connect it. What kind of cable comes out of this thing and where does it go (like maybe a USB slot). I've got a coolermaster case with a standard coolermaster 120mm fan at the back (plugged into the motherboard) and a Vantec 120mm fan at the front also plugged into the motherboard. I can get their rpm details and such in the hardware control.
Old 27-05-2007, 02:12 PM   #5 (permalink)
I hope you will get all the required information from the following link-
http://www.extrememhz.com/aerogate3-p1.shtml
V.Prem Kumar
janitha is offline
Old 27-05-2007, 04:13 PM   #6 (permalink)
 Macboy
goobimama's Avatar
^^ Very helpful. Thanks.
CoolerMaster Hyper48 intel Hardware Q&A 3 06-11-2005 10:36 AM
sm bus controller cybermanas QnA (read only) 1 26-09-2005 03:20 PM
