Old 25-05-2007, 03:50 PM   #1 (permalink)
jal_desai's Avatar
Unhappy cd rw/dvd drive not writing my CDs...
i have asked for the soln of this problem but didnt get the satisfactory answer. tht's y i m posting it again. pls dont delete this post. my problem is tht the combo drive of my laptop is not writing any CDs. it can read DVD/CD flawlessly...but when it comes to burning..it gives problems... i used to write at 16x and 24x but now i cannot see the option to write at high speeds... i get only 4x (see the screenshot below)..
and when i try to burn anything the nero window shows the following error (see screenshot below)...
i am also attaching a log file. chk out tht too... i donno wats the problem.. can u please figure it out and help me to troubleshoot it... i have loads of data pending to be stuffed into CDs...
thnks in advance.
TechExplorer.in
jal_desai is offline
Old 25-05-2007, 04:03 PM   #2 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Default Re: cd rw/dvd drive not writing my CDs...
First Of All Remove Serial No From .log File
Orionz is offline
Old 25-05-2007, 04:11 PM   #3 (permalink)
jal_desai's Avatar
^done tht... can u tell me wats wrong with it?
TechExplorer.in
Old 25-05-2007, 04:50 PM   #4 (permalink)
Plz give info about
Laptop brand & model and the brand of media used.the brand used is very important . coz only good & branded media allow you to write at rated speeds.
also is your laptop under warranty ? The reason is if the problem could be solved by a firmware upgrade and if it leads to a void of warranty , you are better off going to the auth service centre
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 25-05-2007, 05:07 PM   #5 (permalink)
jal_desai's Avatar
Laptop Brand: Compaq Presario M2000
Media Brand: mmm... this is just those CDs we get @ 7 Rs per piece... (is tht the problem???) i have used this kinda CDs before also but never faced such a problem.
and my laptops warranty is over... how much will it cost if i upgrade?
TechExplorer.in
Old 27-05-2007, 12:23 PM   #6 (permalink)
clmlbx's Avatar
try re-installing nero .
try the latest version .
local is ok but don't use below frontech cd's
clmlbx is online now
Old 27-05-2007, 01:44 PM   #7 (permalink)
jal_desai's Avatar
ok dude .. i'll try
TechExplorer.in
Old 27-05-2007, 07:03 PM   #8 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Problem seems to be with Media. As Writer decides the MAX speed. Try with another Quality Media like Moserbear or Sony
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 27-05-2007, 10:49 PM   #9 (permalink)
jal_desai's Avatar
@sukhdeep thnk u too
TechExplorer.in
Old 28-05-2007, 04:13 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
sony media is the best ......... use it only ...........
ax3 is offline
Old 28-05-2007, 04:42 PM   #11 (permalink)
jal_desai's Avatar
i'll surely do it.. but wat if the problem still lingers... i am afraid my hardware is going to be dead soon...
TechExplorer.in
Old 28-05-2007, 05:15 PM   #12 (permalink)
TechTin.com
ravi_9793's Avatar
Is this the problem since U buy the combo drive..OR it was working fine and than gone mad suddendly?
Have you tried burning using windows default.I suggest you to update the driver and nero software.And than try burning it.
Else do one thing...Try ur combo on ur friend's system.Than plz post the result.
ravi_9793 is offline
Old 29-05-2007, 11:15 PM   #13 (permalink)
clmlbx's Avatar
Smile Re: cd rw/dvd drive not writing my CDs...
did u reinstall nero
u r using 6.0
move up latest is 7.9
not want to upgrade
reinstall it
problem is not solved even after reinstalling
then try to upgrade firmware of ur drive .
firmware upgrade
carefully , done worng = drive ?
Old 30-06-2007, 05:55 PM   #14 (permalink)
jal_desai's Avatar
how to upgrade the firmware??? plz tell me??? i m ready to do it now.. i have loads of data ready to be burned into CDs... help me guys... and ofcourse thnks for ur valuable suggestions
TechExplorer.in
Old 30-06-2007, 06:02 PM   #15 (permalink)
TechTin.com
ravi_9793's Avatar
Have you done wht I suggested here???
Old 30-06-2007, 06:10 PM   #16 (permalink)
jal_desai's Avatar
ya but to resounding nothing..
can i update my firmware???
i got this update : SONY CD-RW CRX830E Version JFK2 Firmware Upgrade
whereas my device manager shows : SONY CD-RW CRX830E Version JPK4
should i apply this upgrade.????? is it ok to upgrade a JFK2 version on JPK4 one..??? help me guys
TechExplorer.in
Old 30-06-2007, 06:21 PM   #17 (permalink)
in your face..
karnivore's Avatar
Well i use HP Compaq Pressario V2000 series. I had and currently have the same problem with my combo. The last time i took it to the autorised centre and they replaced the drive. This time around i am having the same problem and i will be taking my notebook to the centre again.
I don't think there is anything else you can do. Also, if your warrenty has not run out or u have Care Pack, just visit your nearest service centre. Thats the best soln. Don't fiddle around.
karnivore is offline
Old 30-06-2007, 06:23 PM   #18 (permalink)
TechTin.com
ravi_9793's Avatar
you can give a try.Before that make a restore point.But that wont help U ,as I think.
Have you checked the drive on ur friends PC??Chances may be there ..that ur drive is not is good conditions.
Old 30-06-2007, 06:31 PM   #19 (permalink)
jal_desai's Avatar
my poor drive... it used to write so many data on my cds... and didnt even said a word.. it did watever i asked it to do... it read film dvds for dozens of hours alltogether... it read even scratched disks... o god i was so cruel to it... i forced it to read scratched dvds and cds... But now its no more... ... however it still reads cds and dvds but when it comes to writing... it gives up... i m so sad...
TechExplorer.in
USB writing pad 4 PC cooldude Hardware Q&A 1 18-10-2006 10:58 AM
problem writing cds in combo drive kjuvale Hardware Q&A 6 19-07-2006 06:37 PM
CD writing in XP...How? linardni Software Q&A 11 19-01-2006 04:30 AM
Help in DVD Writing stalin QnA (read only) 7 10-05-2005 11:02 PM
cd writing noblefriend2002 QnA (read only) 2 20-08-2004 06:03 PM
