Old 25-05-2007, 02:44 PM   #1 (permalink)
Default APC battery replacement
my apc ups battery has come to end of its life. how much will a new battery cost? can i replace the battery myself or do i need a technician. is it possible to use non-apc batteries and replace them myself? how much will non-apc battery cost. my model is back-ups ES 500.
neyo is offline
Old 25-05-2007, 02:47 PM   #2 (permalink)
Default Re: APC battery replacement
If u're too good a techie, u can do it urself...
Better rely on d tech...
Others'd do.... But d proper ratings's a must... Why of corz APC batts're frm OEM I believe....
Mostly some 500 to 600 bucks... DAts it... 500VA... So I guess mus be dat...
Cheers....
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 25-05-2007, 05:45 PM   #3 (permalink)
yup.. u can get a exide battery for ~ 500-600 bucks. most UPS use standard batery..
kooabs03 is offline
Old 25-05-2007, 08:59 PM   #4 (permalink)
Normally UPSs use 12V and 7 or 7.5 AH SMF (sealed maintenance free) batteries, for which you have to pay Rs.500 to 600 in case of brands like Exide. But the question is whether the size and specifications are the same in case of APC also.
V.Prem Kumar
janitha is offline
Old 25-05-2007, 09:07 PM   #5 (permalink)
Beware of the innocent
ilugd's Avatar
for our APC 10 kVA UPS we have to pay 2900. Maybe that is different? It is a 17AH battery.
Life is too short. Have fun.
ilugd is offline
Old 25-05-2007, 10:00 PM   #6 (permalink)
It is...
I'd an APC back ups AVR-500 and used an Exide replacement... All APC ups' makes use of OEM batteries manufactured by others.... Specs're perfect, so is the size...
It jus fits!!!
Go on dude...
Replacement for msconfig Kaushal Hiwarkar Software Q&A 6 23-05-2007 05:41 PM
any way of permanent replacement of IE ??? mohit sharma QnA (read only) 16 25-04-2006 09:26 PM
CMOS battery replacement ashu888ashu888 QnA (read only) 4 26-10-2005 07:11 PM
Shell replacement allindrome QnA (read only) 10 20-12-2004 08:15 PM
