Sure... But you will need a Network switch... Configure your network cards to have IP 192.168.0.x (where x is 1, 2, 3, etc... different numbers for each computer)... Set Workgroup on each computer as the same... Then, you should be able to connect... You can set share permissions for various folders that you want to share...
