Old 23-05-2007, 04:44 PM   #1 (permalink)
thrash_metal's Avatar
Default UPS recomendation
I need to buy a UPS .... preferred time of backup should be atleast 15 mins .... round 30 mins is ideal . Comp config is Intel P4 3.2 , Intel 915G , 1024mb RAM @ 400Mhz , LG , Sony DVD RW , 300*1 + 120*2 SATA Hdd , XfX Geforce 7600GT , Audigy PLatinum Pro Soundcard , Pinnacle PCTV , CORSAIR 620watt PSU , LG 19" monitor . Is there anything I should know before buying a UPS ? Also can anyone recomend me a particular brand (with approx price) ?
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 23-05-2007, 06:36 PM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: UPS recomendation
Is that an LCD or CRT monitor you got there? That Pentium 4 sure is a battery hog. Currently using a Core 2 Duo E4400 + 965 + 1GB DDR + HDD + DVD + 17inch LCD on an APC UPS (the new one which lies flat like a duck) and get around 35 minutes backup time, 40 if there's not much load on the CPU. 500VA. Cost me I think 1.8k though I'm not sure.
I'm like a bird... :)
goobimama is offline
Old 24-05-2007, 07:45 AM   #3 (permalink)
Its a LCD
Old 24-05-2007, 07:55 AM   #4 (permalink)
prasad_den's Avatar
Regarding the brand.. go for an APC..!! Rock solid reliability..!!
prasad_den is offline
Old 24-05-2007, 08:32 AM   #5 (permalink)
Sup' dude, Sup'
APC and nothing else. I have mercury UPS and it sucks.
ambandla is offline
Shud i ignore Vista's recomendation? gg_3000 Software Q&A 11 09-12-2006 07:20 PM
