Old 23-05-2007, 02:56 PM   #1 (permalink)
AJJU
azzu's Avatar
Default LAN problem
i have two computers and want to connect them usin lan i brought lan cables (they are workin properly n checked) but the problem is in Network connection
local area connection is saying a network cable is unplugged
is this problem or somethin else . help me
i have searched forums but didn't got perfect solution
I love and Live to Design
azzu is offline
Old 23-05-2007, 02:57 PM   #2 (permalink)
Default Re: LAN problem
is it cross cable that u r using? also have u assigned static IP adrresses to the systems?
kooabs03 is offline
Old 23-05-2007, 03:34 PM   #3 (permalink)
AJJU
azzu's Avatar
how can i know its cross cable or not and how can i assign static ip adresses to the systems
help??
azzu is offline
Old 23-05-2007, 04:27 PM   #4 (permalink)
ask the vendor for a cross cable. my computer > my network places > view network connections > right click local area connection > properties > select internet protocol > properties > use the following ip add. > put ip adress 192.168.1.1 >click subnet mask > ok. for second system repeat all steps n put IP adress as 192.168.1.2
kooabs03 is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
