Old 22-05-2007, 02:27 PM   #1 (permalink)
royal's Avatar
Question IDE to USB
I plan to convert my internal DVD writer to an external one to be used with my laptop. However I dont plan to buy a 5.25" external drive. Instead I plan to buy this. Can anyone specify where can I find one in Kolkata?
Also I have seen similar products which has both SATA/IDE connection options. Are these available here ?
And lastly, will the transfer speed of USB 2 be sufficient to burn DVDs ?
royal is offline
Old 22-05-2007, 06:27 PM   #2 (permalink)
dissel's Avatar
Default Re: IDE to USB
According to your link
If you want to buy Tech-Com products I can give you the Tel.No of a person who deal Tech-Com Product in Chadni.
2 months ago I purchased external TV-Tuner card from that guy.
__________________________________________________ _________
Distributor of Tech-Com in Kolkata.
Shree Sagarmatha Distributors PVT.LTD
2nd Floor
14,Chandni Chawk Street,Kolkata-72
Mobile:-9830031487,9903039114
But it isn't help you much, Coz they deals in bulk purchase.You can enquire the shop address or availability of the product.
dissel is offline
Old 22-05-2007, 10:21 PM   #3 (permalink)
royal's Avatar
Smile Re: IDE to USB
Please do...
royal is offline
