Old 21-05-2007, 04:44 PM   #1 (permalink)
Default ddr400 on ddr266
hi all, i've an old mobo mercury with 845GL chipset which supports only ddr266. i've a ddr266 256MB module, want to add another 512MB but cannot find ddr266 anywhere. so i was wondering whether i could add ddr400 and use it along with ddt266. i heard a shopkeeper say ddr400 won't run on ddr266. will this give any problems. does this depend on the brand of ram? if i'm correct ddr400 runs at same voltage as ddr266, so what speed will both run at? will i have any problems with restarts or anything? Please someone confirm that they will run fine together even if they're of different brand. Thanks in advance.
neyo is offline
Old 21-05-2007, 05:29 PM   #2 (permalink)
Default Re: ddr400 on ddr266
mixing 266mhz n 400mhz wld cause problems. though i think 400mhz wld work on ur board at reduced speed. but ur best bet wld be to buy a second hand 266mhz RAM frm somewhere.
kooabs03 is offline
Old 21-05-2007, 07:19 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Good RAM's like would be ZION, will support all the 3 sets, 266 , 333 , 400, so go for a ZION 400 which will support and will run at 266 along or side by side with ur Present RAM
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Using DDR400 on a DDR266 M.Board mohanty1942 QnA (read only) 8 23-08-2005 12:32 AM
What is DDR433/466/500/533 , DDR only has a Max DDR400 quad master QnA (read only) 9 16-02-2005 08:38 AM
