Old 21-05-2007, 03:51 PM   #1 (permalink)
thrash_metal's Avatar
Post SMPS Query
Currently i'm using a 300watt Zebronics SMPS ... my comp config is P4 3.2 on Intel 915 , 1.5Gb 400Mhz ram , 300x1 + 120x2 SATA Hdd , Creative Audigy 2 ZS Platinum Pro Soundcard , XfX GeForce 7600GT , Pinnacle PCTV , LG DVDwriter , Sony DVD Writer , Asus StarIce Cooling fan . I am thinking of upgrading my SMPS , but whenever i put in a higher wattage SMPS it seems to blow out !!! It works fine untill I start any heavy application when the system sudenly turns off !!!! Upon restart the green LED on the cabinet glows and also the light on the motherboard but the system doesnt start ... this has happened a LOT of times ... I even got a CORSAIR 620watt Modular Power Supply .... the same thing happened .. what can be the reason for this ? The system is working perfectly on the 300watt . Sometimes the Audigy external Drive suddenly switches off . What could be th problem for this ? Please help .......
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 21-05-2007, 07:57 PM   #2 (permalink)
Default Re: SMPS Query
I was having a similar kind of problem while playing any 3D game ,after a 1 min the PC would just shutdown.Turns out it was the RAM slots which were having trouble running in dual channel mode.I would say try checking each RAM module or borrow a friends RAM stick and see what happens.
Also check the spike gaurd and try a different power outlet.
AMD 64 3000+(Venice Core),MSI K8N Neo4-F,512*2 DDR 400(Dual Channel),200GB HDD(40GB IDE + 160 GB SATA),GeForce 6800 GS,400W VIP PSU,Samsung DVD RW(DL),BenQ 17" LCD(FP71E+),Sony MDR XD-200 Headphones
roydon is offline
Old 22-05-2007, 07:24 AM   #3 (permalink)
In ChA i have 512*2 and in ChB i just have 512*1 ...... can this be the problem ??? RAM @ 400Mhz
Old 22-05-2007, 12:07 PM   #4 (permalink)
A computer wud work with an SMPS havina higher wattage... It doesn do any harm...
Invest in a powersafe or a coolermaster SMPS... At least 500W of them.... U wudn regret payin a li'l xtra... But its cheaper than Antec ones.....
I cant find d problem with the former query.... Connect ever connector to d reqd power inlet... Use d manual n ref to d net... They'll even post images...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 22-05-2007, 08:41 PM   #5 (permalink)
assasin's Avatar
dood r u out of ya mind or somethin???
ur suggesting Powersafe & CM to a guy who has already tried out a Corsair 620W psu which costs the same as Antec.
@thrash_metal ,for exactly how much did ya buy that Corsair 620W psu.
i'm seriously thinkin of buying one when i geta DX10 gpu.
assasin is offline
Old 22-05-2007, 11:27 PM   #6 (permalink)
Smile Re: SMPS Query
Why dont you try using a single 512 stick at a time in the same slot.Use one stick and try loading a heavy application and see if you get shutdowns.It will be slow but the idea is to see if it crashes or not.Try it and post back.
roydon is offline
Old 23-05-2007, 07:19 AM   #7 (permalink)
@assasin .... I got it for 7,500/- ... well thts the cheapest I could get across 10 vendors I asked out here !
And as far as the second thing goes ... leme try it out and post it !
Old 24-05-2007, 07:38 AM   #8 (permalink)
Unhappy Re: SMPS Query
Its not shutting down .. but getting really really HOT !!!! The Intel Desktop Utilities starts falshing warnings at around 78 degrees and then it hangs
Old 24-05-2007, 08:45 AM   #9 (permalink)
Sup' dude, Sup'
try this:
Keep the cabinet door open, put a desk fan blowing air into the cabinet and see if that keep the system up and running.
Reason could be SMPS getting too hot and increase in the temp. inside the cabinet or that Corsair SMPS is not giving stable voltages.
try any other high wattage SMPS and also check how corsair SMPS works with other CPU
If you got this UPS from US or other country, make sure that the UPS is set to 240V-250V operational voltage.
ambandla is offline
Old 24-05-2007, 11:15 AM   #10 (permalink)
What exactly is getting hot? ....and the which component is 78C?
roydon is offline
Old 24-05-2007, 12:30 PM   #11 (permalink)
ancientrites's Avatar
i thinks its UPS that is giving you trouble when you have installed a new smps.
now for moment get that corsair smps and connect it directly to socket.i dont think you will have any problem.see that you dont have anything connected to ups.
ancientrites is online now
Old 25-05-2007, 02:03 PM   #12 (permalink)
assasin's Avatar
if ur proccy is heating upto 78C then remove ur heatsink and clean it throughly,apply AS 5 and then put it back correctly
assasin is offline
Old 01-06-2007, 07:22 PM   #13 (permalink)
Well shifted to Antec Nine Hundred cabinet ..... took the temperature down to 67 degrees (max load) , average is round 55 ...... is this proper ?
Old 01-06-2007, 08:15 PM   #14 (permalink)
assasin's Avatar
still the temps r a bit high.
assasin is offline
Old 02-06-2007, 08:29 AM   #15 (permalink)
So what might be the problem ???? And what should I do next ?
Old 02-06-2007, 08:49 AM   #16 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
For lowering the temperature
1) Put the computer away from direct sunlight
2) Keep the cabinet atleast 1 foot away from walls.
3) Get a table without side walls.
4) Check whether the general heat dissipation equipment is working. Fans etc are clean, heatsink is making good contact etc.
5) Reduce the clutter of cables by tying them ( with non-flammable plastic to prevent burning) and setting them aside away from air flow.
6) Use HW monitor to find out how temperatures are chaning while gaming and idle to identify what is overheating.
7) If room temperautre is very high, get a motherboard which is rated to work at high temperatures like ATI chipsets.
BTW I followed everything I said above and my computer is working fine even on 14 hour gaming sessions and my computer is 24*7 on.
Also I have only 288W SMPS and it can handle ATI mobo, Pentium D (one high power consuming procy) , XFX7600GT and 2 sticks of DDR II and 1 hdd and DVD writer. I think everybody seems to be doing an overkill on SMPS. I am totally confused how my SMPS is handling this load when all those Wattage Calculators on net seem to be saying I need to nearly double the wattage.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 03-06-2007, 07:43 AM   #17 (permalink)
After a bit of observation ..... the processor temperature is suddenly shooting up from 60 to 70 during gaming !!
Old 03-06-2007, 09:11 AM   #18 (permalink)
assasin's Avatar
just remove the heatsink,clean it,apply AS5 and put it back.sud reduce temps a bit.
assasin is offline
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
SMPS query nil_3 QnA (read only) 3 12-06-2006 06:13 AM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
