20-05-2007, 11:37 PM
Help:cpu Fan
My CPU fan is creating lot of noise....I think its fan cover arrangement got a prob...which i tried lottt to solve...but prob is still dere...As I cant tolerate this noise..therfore, planning to buy new cpu fan..suggest me..shuld i go for intel or other brand..as i want performance as well as cooling..
21-05-2007, 12:06 AM
Rising ApocalypsE
Re: Help:cpu Fan
If u have money then buy something from Cooler Master or Thermaltake,depending on ur budget.
21-05-2007, 12:53 AM
Re: Help:cpu Fan
whts d approx. price of intel cpu fan n tht of coolermaster or thermaltake...
21-05-2007, 07:29 AM
Re: Help:cpu Fan
i have the same problem since about 2 weeks my system fan has become VERY noisy. usually i just clean the dust from my system fan and the noise goes away but this time it didnt work. what can i do cuz i cant really buy a new one.
21-05-2007, 07:26 PM
Rising ApocalypsE
Re: Help:cpu Fan
Cooler Master Price list
http://www.theitwares.com/coolermaster/coolermaster.htm
I have the Hyper 48 & i bought it for 3850/-
22-05-2007, 10:53 PM
Re: Help:cpu Fan
Wht is the price of Intel CPU fan ??
22-05-2007, 10:57 PM
Re: Help:cpu Fan
Did you clean your cabinet with a vacum cleaner? If not, use a small car vacum cleaner or if you a home one then use it.
BUT BE CAREFUL. DON'T DO IT IN SUCKING MODE. BLOW AIR FROM THE VACUM CLEANER INTO YOUR CABINET. IF ANYTHING HAPPENS, AND YOUR COMP. GOES OFF, DON'T BLAME ME
KDE on ArchLinux
23-05-2007, 12:18 AM
Re: Help:cpu Fan
Cabinet is properly cleaned and ventilated...I know...dere is some prob in adjustment...thts why...I am planning to buy new cpu fan...
23-05-2007, 11:36 AM
Re: Help:cpu Fan
Do as you wish.
KDE on ArchLinux
23-05-2007, 10:29 PM
Rising ApocalypsE
Re: Help:cpu Fan
There is nothing called Intel CPU fan....well technically not because they all use differnt companies fan.Its all about the adjustments over the CPU.U can even use an AMD's CPU fan!
Anyways,few of the Intel CPU uses Cooler Master fans.So the same will cost arount 200-400/- max.If it is higher than this then go for the copper heatsinked fan.
or
U can go for a used fan+HS,get it from any vendor!
