Old 19-05-2007, 02:27 PM   #1 (permalink)
Default Problem With Comp-video Out...
Guys...
Dis 7900GT...
Cant hook it up with my SONY Wega TV.... It has a comp video input in the front panel as well as back...
The back one's plugged to the DVD sys....
Wen I hook to the front one, it doesn sense anythin....
Any clues...
Pl....
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
gannu_rox is offline
Old 19-05-2007, 03:22 PM   #2 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Default Re: Problem With Comp-video Out...
What is 'comp' in your terminology? Component or Composite?
As for as I know, Sony WEGA doesn't have a Component plug in front Panel. Are you sure it's not AV IN? (Audio, Video In)
AV in has three pins(Yellow, Red, White/Black) while Component has three Pins with RED, GREEN & BLUE color. The yellow Pin in AV is called as composite.
Why don't you try the Sony's flagship S-Video cable? All Sony TV's having S-Video. (I hope old SONY models will accept only one Component which you have already used to connect your DVD Player, isn't it?)
Have you run the TV CONNECTION wizard from your NVidia control panel?
Follow these steps:
1. If you have 2 COMPONENT Input in your TV, connect your system thru component. (I hope you already used one for DVD)
2. If you have only one COMPONENT In, then use the S-VIDEO out of your 7900 to connect to your TV.
3. Run NVidia control panel TV Wizard, choose the correct connector type, then choose the format as 576i (I hope you are not using SONY HD TV), then select CLONE/DUAL mode.
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Old 04-07-2007, 07:05 AM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Originally Posted by gannu_rox
Guys...
Dis 7900GT...
Any clues...
Pl....
This was my explanation....might help....
http://www.thinkdigit.com/forum/show...6&postcount=13
sam9s is offline
Old 05-07-2007, 03:28 PM   #4 (permalink)
Gav away my card sam.... Thanx fer d reply... But anyways wont hook my new 8800GTX to the tv coz of the dell 19"...
Thanx budd... Dats reeally helpful...
Old 05-07-2007, 06:55 PM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
congratts for the new awsome 8800GTX....
sam9s is offline
Old 05-07-2007, 09:15 PM   #6 (permalink)
Heh he... Thanx sam... Yet to hook it to a p5K Del + E 6850....
Old 05-07-2007, 10:39 PM   #7 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Well if u have the S-VideoAV cable (normally comes with the card) then YES but u have to read the manual then u can surely use your TV with the card.
I have 6800 GS and i have played many games on my TV.
keith_j_snyder2 is offline
comp hang when playing video file dNextAxiom Software Q&A 12 18-04-2007 03:01 PM
output video from comp 2 tv along with scrolling text(urgnt) manmay Software Q&A 3 26-01-2006 06:07 PM
