Old 19-05-2007, 12:14 AM   #1 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Which is better?
I want to buy the Dell Inspiron 640 and got stuck with the graphic card option in the customization menu . I have to choose from "256MB ATI Mobility Raedon X1400 Hypermemory" and "256MB NVIDIA GeGorce Go 7300 Turbocache" . I want to know whose performance is better? Is it possible to play FEAR @ 25fps(at least) with either of the cards in 1440*900 resolution ?
debsuvra is offline
Old 19-05-2007, 12:21 AM   #2 (permalink)
Default Re: Which is better?
first of all the dell inspiron cannot display more that 1280x800(i think)....second.. the nvidia option shud give u a better performance...it costs u slightly more too ....n whether fear will work on not depends on the amount of ram too...should work fine with 1 gb but not with all the effect in high mode.....
Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour, and it seems like a minute.
That\'s relativity - Albert Einstein
great_manish is offline
Old 19-05-2007, 12:43 AM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
For ur info Inspiron does support 1440*900 res with their "Truelife" offering. The system has 1GB of RAM .
debsuvra is offline
