Hello, friends i want to buy a LCD TFT Monitor. My budget is rs. 11800.
Guys suggets me some best 17 or 19 inch (preferable) tft monitors within my
budget. Also suggets some models which have DVI connectivity.
As for the resolution not being listed..............just connect your widescreen LCd and it will automatically detect the 1440*900 resolution.
If you can raise your budget by few hundred. Get your hands on ASUS 19inch Widescreen TFT since it has DVI and very good view angles and very very Good Contrast ratio of 800:1
